iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News |
03-24-2013, 08:32 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: IN YOUR HEART :)
Member: 1243555 Status: Offline Thanks Meter: 661 | How To Jailbreak (Tethered) iPhone, iPod Touch On iOS 6.1.3 Using Redsn0w However, devices with an A4 processor can receive a tethered jailbreak , which this tutorial will describe. Note 1: This guide describes a tethered jailbreak for A4 devices (iPhone 4, iPhone 3GS, iPod touch 4G) using the latest redsn0w version only Note 2: If you are not on iOS 6.1.3, it is recommended that you DO NOT UPGRADE, since this will ruin any current untethered jailbreaks. Note 3: Before jailbreaking with this tutorial, it is recommended that you read through it first, so you can become familiar with the steps. Note 4: if your iPhone is unlocked via Ultrasn0w, you should stay away from iOS 6.1.3 becasue there is no unlock solution available for now. Compatible Devices:
Requirements : Step 1: Download the original iOS 6.0 from the link provided above. Step 2: Download Redsn0w 0.9.15b3. Link provided above. Step 3: Connect your A4 iDevice to your computer. Step 4: Double click the redsn0w zip file and extract it. Navigate to the extracted redsn0w folder, and launch the redsn0w application. Note 5: Windows XP and Windows 7 users should run Redsn0w as ‘Administrator’ (right-click on the Redsn0w exe and select ‘Run as an Administrator’)Step 5: Click on ‘Extras‘, then click on ‘Select IPSW‘. Point redsn0w to the 6.0 firmware, which you downloaded in step 1. Step 6: Go back to redsn0w’s welcome page, and click the ‘Jailbreak’ button Step 7: Redsn0w should now start preparing the jailbreak data. Step 8: Now you may select your jailbreak options – we only recommend that ‘Cydia‘ is selected. Then click ‘Next‘ to continue. Step 9: Now you will have to put your device into DFU mode. Redsn0w will guide you through the steps below:
Step 10: After redsn0w detects your device, and if everything has gone successfully, then your device will reboot, and a pineapple logo will appear, indicating a tethered boot. You will now have to wait for the process to complete Once it is complete, you should see the lock screen on your iOS device but Cydia still missing Step 11:Launch Redsn0w again and click on “Extras” button Then “Select IPSW” button and Point redsn0w to the 6.0 firmware, which you downloaded in step 1 Step 12: Then click on the Just Boot button. Step 13: Now you will need to put your device is DFU mode, follow the steps on step 9 If all of the above went according to plan, then congratulations! You have jailbroken your A4 device. In order to boot your device from now on, you will need to connect it to your computer, open redsn0w, then go to ‘Extras’, and click on ‘Just Boot’ [video] on how to jailbreak A4 devices on iOS 6.1.3 |
The Following 12 Users Say Thank You to talhagsm143 For This Useful Post: |
04-03-2013, 12:37 | #2 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: GSM world Age: 49
Member: 111249 Status: Offline Thanks Meter: 531 | Quote:
BR U can also visit HERE for details... | |
04-03-2013, 14:36 | #3 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | Quote:
Originally Posted by kaushikbhadra but sir no service ios 6.1.3 after this trick any more solution pleace help meeeeeeeeeeeeeeeeeeeeeeeee and good work reinstall the ipad baseband n then unlock ur 3GS again, problem will b solved... BR yes this is real solution now i have network the iphone is working perfect tested by me for two iphone 3gs newBR | |
04-04-2013, 05:09 | #4 (permalink) |
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | if you power of the iphone no network so will need to connect it to your computer, open redsn0w, then go to ‘Extras’, and click on ‘Just Boot’ use this until final solution |
