iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News |
01-03-2017, 10:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: HongKong
Member: 2494453 Status: Offline Thanks Meter: 200 | How to Restore A Disabled iPhone Using 3uTools? If you enter the wrong passcode in to an iOS device for many times, your iDevice will be locked out and a message will show that your iDevice is disabled. Unless you made a backup before you forgot your passcode, there isn’t a way to save your iDevice’s data files. Solutions: This tutorial is mainly introducing how to restore a disabled iPhone using 3uTools. Warm prompt: * You’re suggested to backup your important data files from time to time. * If your iPhone is disabled, it can not be connected to 3uTools, so please set your iPhone in Recovery mode/DFU mode before flash. * If your iPhone is disabled, you can not backup the data files on iPhone. Step1: Ensure that you’ve downloaded and installed the latest 3uTools on PC. Connect your iPhone to PC using the USB cable. Step2: After it’s connected successfully, click “Flash & JB→ Easy flash”→ select the available iOS firmware for your iPhone→ click “Flash”. Note: Don’t select “ Retain User’s Data While Flashing”. Step3: 3uTools will automatically download the firmware and flash your iPhone, you just need to wait until this process ends. Besides, please keep a good connection between your iPhone and PC. Step4: After this process is completed, please click “ Pro Flash→Activate” to activate your iPhone. And then, you just need to set region, language and other settings on your iPhone. Or you may manually activate your iPhone on device. |
The Following 5 Users Say Thank You to Supermarios For This Useful Post: |
01-05-2017, 16:45 | #3 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | what is error 50 in 1 and error 50 in itunes? in 3u tool it is error 1 and itune error 50 iphone 6.. firmware 1.2 itunes also latest and 3u also latest? |
01-06-2017, 17:53 | #5 (permalink) |
Insane Poster Join Date: Aug 2006
Member: 330143 Status: Offline Thanks Meter: 4 | its conectivity i done i phone 6 plus same error 50 reheat to bassbend ic 3 or 4 time but not done then i resoldring to charging connecter and resolding ground legs and connecter after i retry to softwear its done i m sure its not basbend problem its just resold charging connector take out charger connecter and resold boths legs at pcb and connecter after put again and instal the softwear i hope it done INSHA ALLAH |
01-11-2017, 14:41 | #7 (permalink) |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | iTunes Error (Error -50) ----------------------------------------------------------------------------------- Delete Storm Vedio, QuickTime, iTunes, then reinstall iTunes. See also Apple's KB article. iTunes Error (Error 1) ----------------------------------------------------------------------------------- Unable to downgrade. Try changing the USB port (the back one of chassis is better) and restart computer The installed version of iTunes may also be too old. Update iTunes. |
The Following User Says Thank You to Shikhar12 For This Useful Post: |
02-09-2017, 12:55 | #9 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Ethiopa Gondar City
Member: 481744 Status: Offline Thanks Meter: 30 | Below devices support to professional flash: iPod Touch2, iPod Touch3, iPod Touch4, iPod Touch5, iPod Touch6 iPad1,iPad2,iPad3,iPad4,iPad Air,iPad Air2,iPad mini/2/3/4,iPad Pro iPhone3G,iPhone3GS,iPhone4,iPhone4s,iPhone5,iPhone 5c,iPhone5s,iPhone6,iPhone6 Plus --------------------------------------------------------------------------------------------------------------------- Steps to enter DFU mode: 1. Keep device in normal mode or recovery mode, plug USB cable (please don't use USB extension cable) 2. Hold HOME button, then hold power button until screen is blank 3. Release the POWER button after about 4 seconds, but keep holding the HOME button for about 10 seconds --------------------------------------------------------------------------------------------------------------------- 14:33:46 Friendly reminder: 14:33:46 Please make sure device turned off 'Find My iPhone' 14:33:46 The device will can not activated without Apple ID after flash, in case device turned on 'Find My iPhone' 14:33:47 Method to check: Settings -> iCloud -> Find My iPhone --------------------------------------------------------------------------------------------------------------------- 14:33:47 Please connect USB cable to apple mobile device, make sure you are in DFU mode14:33:59 User stopped operating, error at line 14825 14:33:59 Failed to flash 14:33:59 If the device doesn't exit current mode 14:33:59 Please hold the HOME and POWER buttons for about 10 seconds 14:33:59 Flash and jailbreak of apple device, please visit official website of 3uTools 3uTools | iOS jailbreak & flash tool 14:33:59 Elapsed Time: 00:00:12 ---------------------------------------------------------------------------------- Activation of device used in: Use for activating the new unactivated device Use for activating the flashed unactivated device ---------------------------------------------------------------------------------- Activation supports below device: iPad1\2\3\4\mini\mini2\mini3\mini4\Air\Air2\Pro iPod Touch2\3\4\5\6 iPhone3G\3GS iPhone4\4s iPhone5\5c\5s\SE iPhone6\6 Plus\6s\6s Plus iPhone7\7 Plus ---------------------------------------------------------------------------------- Steps of activating device: 1.Insert the SIM card into device(iPad.iPod ignore this step), SIM card of corresponding carrier needs to be inserted into the locked device 2.Please make sure device under the normal status 3.Please connect your device to your computer using the USB cable ---------------------------------------------------------------------------------- 14:51:18 Checking AppleMobileDevice service14:51:18 Waiting connect in normal mode14:51:18 Retrieving device's information14:51:18 Unique Device ID: 4a5535d30244ebc2be84a2080dffb84e5fb868c6 14:51:18 Device Class: iPhone 14:51:18 Build Version: 11D257 14:51:18 Product Type: iPhone3,1 14:51:18 iOS Version: 7.1.2 14:51:18 Obtaining activating data14:51:21 Activating14:51:22 Operations are completed 14:51:22 Elapsed Time: 00:00:04 tanks 3uTools tame |
The Following User Says Thank You to nura1335 For This Useful Post: |
02-22-2017, 09:40 | #10 (permalink) | |
Member: 2494453 Status: Offline Thanks Meter: 200 | 3uTools exe. Quote:
Please check this website: http://url.3u.com/zmAJjyaa | |
The Following User Says Thank You to Supermarios For This Useful Post: |
02-22-2017, 09:48 | #11 (permalink) | |
Member: 2494453 Status: Offline Thanks Meter: 200 | error 1 Quote:
Some error codes share the same solution. For more details, you can join us in Facebook: https://www.facebook.com/groups/3uTools/ | |
02-28-2017, 04:40 | #12 (permalink) | |
Member: 2494453 Status: Offline Thanks Meter: 200 | Error Quote:
