Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > Iphone, iPad - FAQ, Guide, How To, Tutorials
Iphone, iPad - FAQ, Guide, How To, Tutorials iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides and Tutorials
Old 08-17-2012, 10:07   #1 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
[iPhone For Newbies] [All in One][Guide]
iPhone For Newbies Guide
iPhone 2G
3.1.3
1- Download 3.1.3 Firmware From Here iPhone1,1_3.1.3_7E18_Restore.ipsw
2- Put Your Phone in DFU MODE
How To and open itunes Your Phone Should be detected Click Ok And Hold SHIFT Button In Your Keyboard and Click Restore and Select Firmware You Already Downloaded.
3-Now Any iPhone 2G is Factory Unlocked So All You have to do is Just Connect Your iPhone To iTunes With Sim inserted and It Will be Activated .
4- If You Need To Jailbreak it You Can use Spirit is Easier Way to jailbreak Download it From
here It's Simple Connect Your iPhone and Click on Jailbreak
iPhone 3G
4.2.1
1-Download 4.2.1 From here iPhone1,2_4.2.1_8C148_Restore.ipsw
-if You Have Factory Unlocked iPhone Simply Follow This ( Put Your Phone in DFU MODE
How To and open itunes Your Phone Should be detected Click Ok And Hold SHIFT Button In Your Keyboard and Click Restore and Select Firmware You Already Downloaded)And Connect Your iPhone to iTunes to Activate it If You Need Jailbreak Use Redsn0w If You Don't Know How Follow This
2-If You Don't Have Factory Unlocked iPhone
-You Will Need Custom Firmware You Can Create it With Sn0wbreeze and Redsn0w or iREB
-Create Custom Firmware With Sn0wBreeze here's How To and You Can Use Sn0wBreeze to Enter Pawned DFU Mode after Firmware is created
-use iReb or Redsn0w to Enter Pawned DFU (either You Will Get Errors)
-Restore Your iPhone With Custom Firmware You Made With Sn0wbreeze With Holding SHIFT And Clicking on Restore
-if You Already Have 6.15 Baseband You Don't Need To Jailbreak the iPhone it's Already Jailbreak With Custom Firmware
-If You Don't Have 6.15 Baseband Use Redsn0w And Tick install iPad baseband and Jailbreak
-Just Open Cydia And Go To Sources And Open Repo666.ultrasn0w.com and Install ultrasn0w.
iPhone 3GS
5.1.1
1-Download 5.1.1 From here iPhone2,1_5.1.1_9B206_Restore.ipsw
How To and open itunes Your Phone Should be detected Click Ok And Hold SHIFT Button In Your Keyboard and Click Restore and Select Firmware You Already Downloaded)And Connect Your iPhone to iTunes to Activate it If You Need Easy Jailbreak Use Absinthe Connect and Click Jailbreak .
2-if You Don't Have Factory Unlocked iPhone
-You Will Need Custom Firmware You Can Create it With Sn0wbreeze and redsn0w or iReb
IMPORTANT Select Baseband Preservation Mode Only With No Jailbreak (To be able to fix Searching Problem ).
-Use Redsn0w And Tick on install ipad Baseband and Jailbreak and Click Next IF You Already Have 6.15 and Need To Downgrade it Tick on Downgrade ipad baseband instead of install ipad baseband
VERY IMPORTANT WARNING ABOUT iPhone 3GS Before You install ipad baseband
[Warning] iPhone 3Gs New Baseband Flash Chip [INFO]
or Download Checker inside Threa
d
iPhone 4
5.1.1
1-Download 5.1.1 From Here iPhone3,1_5.1.1_9B206_Restore.ipsw
-if You Have Factory Unlocked iPhone Simply Follow This ( Put Your Phone in DFU MODE How To and open itunes Your Phone Should be detected Click Ok And Hold SHIFT Button In Your Keyboard and Click Restore and Select Firmware You Already Downloaded)And Connect Your iPhone to iTunes to Activate it If You Need Easy Jailbreak Use Absinthe Connect and Click Jailbreak
-if You Have The Only Unlock able Baseband 1.59 You Will Need Custom Firmware You Can Create it With Sn0wbreeze and redsn0w or iReb
-Just Open Cydia And Go To Sources And Open Repo666.ultrasn0w.com and Install ultrasn0w. Or Search for ultran0w Fixer if it didn't Work
-Same Steps if You Are Have 4.10 , 3.10 ,2.10 and using Gevey sim and You Want to preserve Baseband
iPhone 4s
5.1.1
1- Download 5.1.1 From here iPhone4,1_5.1.1_9B206_Restore.ipsw
2-Simply Follow This ( Put Your Phone in DFU MODE How To and open itunes Your Phone Should be detected Click Ok And Hold SHIFT Button In Your Keyboard and Click Restore and Select Firmware You Already Downloaded)And Connect Your iPhone to iTunes to Activate it If You Need Easy Jailbreak Use Absinthe Connect and Click Jailbreak
Tips And Tricks
How to Enter DFU Mode With a Broken Home or Power Button
No Wifi Unlock Way http://forum.gsmhosting.com/vbb/f456...rizwan-948886/
How to Put an iPhone Into DFU Mode
Pass Code Read Without Restoring http://forum.gsmhosting.com/vbb/f456...olkit-1424749/
Error 3194 Go To C:\WINDOWS\system32\drivers\etc and OPEN host file With notepad and remove Last line should look like this 74.208.105.171 gs.apple.com
if i Forgot Something Please Reply Here
Hoping This Helps More Than Previous Guide
Use thanks button only please
Old 08-26-2012, 19:26   #2 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
Create Account Without Credit Card ( Free)
Creating an iTunes Store, App Store, iBookstore, and Mac App Store account without a credit card
So we can keep it clean and easy to find
The Guide is Very Very Simple and Easy So Don't Ask For Help With Something Already #Explained
[Guide] 5.0.1 Upgrade And Downgrade Problems
The Following 11 Users Say Thank You to ~AhmedLeO~ For This Useful Post:
Old 08-31-2012, 09:27   #3 (permalink)
irfan_gsm's Avatar
Member: 709520
Sonork: 0779883311
pls post a guide how to use cydia to download 3rd party applications.
Old 09-01-2012, 00:21   #4 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
Am already working on that guide and apps cracked deb thanks for suggestion anyway
The Following 2 Users Say Thank You to ~AhmedLeO~ For This Useful Post:
Old 09-01-2012, 20:39   #5 (permalink)
Member: 1519887
Arrow Ip 2g jailbreak problem
hellos sir , itried these all ways but i think u not read my post carefully ....
i did jailbreak one ip 2g morning but on second one i get failed i did b4 postig here all tricks sprit and redsnow 0.9.4 and snow breeze also but getting error of not recognising ,i restore 6 to 7 times to 3.1.3 and 3.1.2 also but failed ....now at last my phone when connected with itunes giving error of 0x80080101 this is the final ???????????
The Following User Says Thank You to mahmood99 For This Useful Post:
Old 09-01-2012, 20:44   #6 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
Thnx for posting here so we can help u
Did u restored your phone?
Did u tried. To jailbreak with spirit ?
The Following User Says Thank You to ~AhmedLeO~ For This Useful Post:
Old 09-02-2012, 10:01   #7 (permalink)
Member: 1519887
Arrow
sir itried a lot may be 10 t0 12 times but failed and at last stuck on error that itunes not comunicating with phone giving error now today i am triying with snowbreeze any update found i will inform with thnx
Old 09-02-2012, 10:40   #8 (permalink)
Member: 1519887
Arrow
sir here is the log for spirit jailbreaking but fail
INFO: Now listening for devices...
INFO: read igor/map.plist
INFO: Connected to the AppleMobileDevice.
INFO: Version iPhone1,1_3.1.3
INFO: Connecting to mobilebackup...
INFO: Sending files via AFC.
FATAL(__LINE__): Assertion failed (dl.c:198): 0 == (AMDeviceStartService(dev, service, &it, NULL)) (but it was -402653091)
198
Old 09-02-2012, 11:23   #9 (permalink)
Member: 1519887
Arrow plz ADD SNOWBREEZE IN UR JAILBREAKING GUIDE FOR IP2G
SIR I TRIED WITH SNOWBREEZE AND GET SUCCEDED TO JAIL BREAKON 3RD TRY PLZ ADD THIS ALSO IN UR GUIDE WITH THANXS TO
kali_fuchi
WHO GUIDE ME
THANX
Old 09-03-2012, 17:29   #10 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
kali_fuchi
WHO GUIDE ME
THANX
with snow breeze u installed new software that's exactly What i Said but u don't have sn0wbreeze original will do the trick READ the Guide Carefully
Old 09-04-2012, 16:22   #11 (permalink)
Member: 1061035
Sonork: raza
Hello Every One Can Eny One Tell ME plese How To chek iphone is Factory Unlocked Or Not ... Plese M very Thankfull to All of you...!! Yu can send me the procedure in privte msg plese....
Old 09-04-2012, 16:39   #12 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
[ CARRIER Check Ways ]
Old 09-16-2012, 03:59   #13 (permalink)
nura1335's Avatar
Member: 481744
Sonork: nura1335@yahoo.com
Help me to flashing the baseband pales
I have this iPhone 3GS is New Bootrom 359.3.2
Firmware version 4.3.5 (8L1)
Serial Number xx138xxxxxx
Modem Firmware 05.16.02
I downgrading the phone
Phone is ok I am using to downgrade TinyUmbrella and Radesn0w
Firmware version 4.1(8b117) Serial Number is Ok Modem Firmware 05.16.02 but I am confessed to update the BB don’t for get the phone is NEW BOOTROM 359.3.2 and date is 2011 38 week
Thank you for helping me
The Following User Says Thank You to nura1335 For This Useful Post:
Old 09-23-2012, 14:04   #14 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 100.1592732
now time to update/edit thread for ios 6 versions.
bcz this thread is very helpfull and safe some time of users!
Old 09-24-2012, 01:39   #15 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
yeah but Whenever Redsn0w with untethered jailbreak is released Guide will be Updated immediately
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.47000 seconds with 11 queries
