Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials
iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides and Tutorials
Old 09-22-2010, 09:19   #61 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 151
When trying to restore Iphone 4G 4.1 version via Itunes10 version always breaks in the middle and occurs error 1004.After using ireb phone is ok.
What is the problem?
Old 09-22-2010, 10:01   #62 (permalink)
Member: 380077
Sonork: 100.1601214
Thanks Meter: 55
sir, i have ipod 2g its always gives me this error 3194 and read the instructions given but i have download the 4.0.2 firmware still the same error and my problem now is that i don't have the SHSH backup so, is there any other way to fix this problem.
regards
Old 09-22-2010, 23:46   #63 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
This happens if you cannot update the baseband. Reason for this is 99% that you changed your hosts file to point to Saurik server. If you really want to upgrade your baseband to make it unlockable, remove the line with gs.apple.com from your hosts file, reboot and retry. When you start TinyUmbrella and close it, it's changed back. This is a security mechanism to prevent people from upgrading their baseband. If you upgrade your baseband to version 2.10.04 (of did that already), then there's no way back and you cannot unlock it. To unlock it you still need a jailbreak of course and there is no jailbreak for firmware 4.1 right now (at least not for iPhone 4). But if you have an Apple-unlocked phone, you can upgrade your baseband of course.
Press thanks button if this helped.
The Following User Says Thank You to https For This Useful Post:
Old 09-22-2010, 23:55   #64 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
regards
To install or resinstall any firmware version, you need shsh file. For current firmware 4.1 you get it from Apple.
Without shsh backup on Cydia you cannot downgrade to 4.0.2. You can only install 4.1, because Apple still gives out shsh for 4.1.
But better you check with TinyUmbrella tool first: In Advanced, select Cydia and version 4.0.1. Then click "Save SHSH" button. If it says "you're too late", then shsh for 4.0.1 is NOT on Cydia. Retry for all versions.
BUT: You're lucky and have an old ipt2. This device has no shsh check built-in. This means that this check is done by the new iTunes. With any other tool to install firmware you can still install ANY firmware there without having shsh! I think the redsn0w tool should work for you.
Press thanks button if this helped you.
Old 09-23-2010, 14:03   #65 (permalink)
Member: 1333151
Originally Posted by https View Post
Probably -9812. Also a time settings problem?
its not the time setting i set the right time
i tried on internet and got this link
iTunes: "Error -9812" when accessing the iTunes Store
but still when i click update it says page not found
please help
Old 09-23-2010, 15:25   #66 (permalink)
Member: 1060560
Originally Posted by delower10 View Post
Error 20000
Its cause by custom pack theme on ur windows. Use default Theme.
Delower
thanx sir..
error 23 on iphone 2g while restoring to 3.1.3
thanx guys...
Old 09-25-2010, 10:00   #67 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 456
error 1610 ????????????????????????
Old 09-28-2010, 08:52   #68 (permalink)
skytelecom's Avatar
Member: 1074229
Sonork: 100.1605299
Thanks Meter: 63
ist wen i restor firmware its show error 28 . i change the cable conector . now its showing error 1618
error 1618 ??????????????????????????????????????
Old 09-28-2010, 09:16   #69 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,406
Arrow
Itunes Error 1618 : missing system files or broken corrupt data itunes installation. Try to uninstall itunes, restart computer, & install again.
@ rajeshchiyyan U can try This !
Delower
Old 10-01-2010, 11:32   #70 (permalink)
Member: 18057
Thanks Meter: 62
new error 28 with 3gs updating
Old 10-01-2010, 11:37   #71 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
Error 28:
Hardware error. Return your device to Apple if possible. The problem is a bad dock connector on the iPhone. Must change the connector.
Old 10-01-2010, 12:10   #72 (permalink)
Member: 1022280
Thanks Meter: 14
sir i have same problem what can i do.......?
all the i phone same problem!!!!!!
Old 10-02-2010, 09:53   #73 (permalink)
Member: 1199618
I just got a disabled ipod touch 2g...i restored it... after that .. try to install application ...When i sync any ..its says that .."This xyz application was not install because the ipod touch is not verified"
something like that ....
Old 10-02-2010, 10:39   #74 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,406
Arrow
Install mobileinstallation file (Appsynce in sydia)
Delower
Old 10-06-2010, 07:24   #75 (permalink)
Member: 194873
Thanks Meter: 4
Dear mate, There i sno error code but my iphone was not recognized with itunes in windows 7....if i put my iphone in recovery its working fine...i mean its connecting and displays that ur iphone is in recovery mode.....my iphone connects with others pc...so please do kindly advice me the solution as soon as possible...awaiting for your reply.....
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 04:52
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.43355 seconds with 9 queries
