iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News |
06-06-2013, 08:19 | #369 (permalink) |
Freak Poster Join Date: Jun 2010 Location: india(Bhuj kutch ) Age: 34
Member: 1326709 Status: Offline Thanks Meter: 39 | Itunes Error Collection With Solution Iphone Error Collection With Solution Errors -9815 Set exact date, restart computer. See also Apple's KB article. Errors -9814 Set exact date, restart computer. See also Apple's KB article. Errors -9800 Set exact date, restart computer. See also Apple's KB article. Error -50 Delete Storm Vedio, QuickTime, iTunes, then reinstall iTunes. See also Apple's KB article. Error -35 See Apple's KB article. Error 1 Unable to downgrade. Try changing the USB port (the back one of chassis is better) and restart computer. The installed version of iTunes may also be too old. Update iTunes. Error 2 Sn0wbreeze 1.6 Custom Firmware has a ASR patch problem. Use sn0wbreeze 1.7 or PwnageTool. Device isn't bootable. Error 6 Not enter the downgrading mode, change USB port (the back one of chassis is better) and restart computer. Error 10 LLB is missing from the IPSW. The device cannot be booted up. The trick to skip the baseband update no longer works. Error 11 Removed bbfw file in the firmware folder of an unzipped IPSW. Error 13 Occurs when you want to install a beta firmware with iTunes for Windows (actively blocked by Apple; beta users are developers and therefore must have a Mac). Error 13 may also signify a USB problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable. Error 14 Custom firmware update fail (PwnageTool). You have to restore the device with a custom firmware. Update to a custom firmware isn't working. Device isn't bootable. 2 USB Problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable. Error 17 Custom firmware update fail (sn0wbreeze). You have to restore the device with a custom firmware. Update to a custom firmware isn't working. 2 Error 20 Searching correct fault. Error 23 Searching correct fault. Error 26 False version of the NOR flash firmware. Use the correct sn0wbreeze version. Error 29 See Apple discussions thread about this problem. Error 37 iPod touch 2G LLB patched with the 0x24000 Segment Overflow was used on an iPhone 3GS custom firmware. Known on damaged bundles from unofficial PwnageTool distributions or bundles. Error 1002 Are you restoring to a stock apple firmware or a custom pwn firmware? Either way make sure you are in DFU mode first. Error 1004 This is caused by a failure to match the Baseband Nonce currently in memory to the Nonce returned in the BasebandFirmware SHSH blob. This is a normal part of iPhone 4 local restores via TinyUmbrella. 1 Error 1013 Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.0.2 firmware downgraded from 1.1.1) Error 1014 This error is down to itunes not liking your USB ports on your computer. Use a different USB slot or a different computer if possible. That is the easiest fix! Error 1015 Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.1.1 firmware downgraded from 1.1.2) Baseband firmware on the IPSW is higher than the baseband firmware on the iPad/iPhone. 1 Error 1413 Restart computer; change USB port; reinstall system. See also Apple's KB article. Error 1415 Restart computer; change USB port; reinstall system. Error 1417 Restart computer; change USB port; reinstall system. Error 1418 Restart computer; change USB port; reinstall system. Error 1428 Restart computer; change USB port; reinstall system. Error 1600 Custom firmware can't be restored on a device with DFU Mode. Use Recovery Mode. Error 1602 Restart computer; change computer; reinstall system. Error 1603 False kernelcache patch. Known on damaged bundles from unofficial PwnageTool distributions or bundles. See also Apple KB article Error 1604 Device was not pwned (signature checks were not blocked). Custom firmware can't be restored. Error 1611 iTunes tried to enter the Restore Mode, but the device turned back to the Recovery Mode. Error 1619 iTunes is too old and couldn't read the iPhone in Recovery or DFU Mode. Please update iTunes and try it again. Error 1644 IPSW was moved during prepare with iTunes. Try it again and don't move the IPSW. Error 2002 iTunes can't connect because another program is using it or it's disconnected during the Apple Server check. Error 3XXX iTunes can't connect to gs.apple.com. Maybe Port 80 and Port 443 is blocked. Open it on your router. Error 3002 Update to an older firmware isn't working, because Apple is no longer handing out SHSHs for the device/firmware combination. Error 3004 No internet connection during the firmware restore. Error 3014 False edited hosts. The SHSH request couldn't be completed. No connection to the Apple Server, Sauriks Server or localhost. Error 3194 Occurs when trying to install an old firmware and Apple's server disallows the installation. The only solution is to have SHSH backup and modify the hosts file to point to Saurik's Cydia server where they are backed up (or localhost if you have it yourself). Error 3195 "An internal error occurred." Missing SHSH for the firmware. Maybe the same as "This device isn't eligible for the request build." but with an cache error. Error 11222 internet options Connections tab Click LAN Settings uncheck "use a proxy server" 0xE8000022 Searching.......... 0xE800003D False permissions in the Carrier Bundle folder. Restore, update or fix the permissions from the carrier bundle to update the carrier settings via iTunes. 0xE800006B Device was suddenly unplugged. iTunes couldn't connect with the device. Try it again. 0xE8000065 sn0wbreeze custom cirmware error on USB connection. Unplug the device, reboot it, and plug it in again. |
09-22-2015, 23:39 | #373 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | fllow this link Quote:
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
