How to Erase Software for Mac? How to Erase Software for Mac? uninstall software mac with software removal on mac! Why should we uninstall software mac? We usually use the computer in the process, often install some software, but some software may use the frequency is very low, or no longer used once or twice, used, regularly delete unused software can save disk space and improve the system efficiency. removing software for mac is advanced and professional software which designed for Mac user to clearing software on mac Now many computer users due to work and had to download some office software, but not to long-term use of these software, so removing software from mac can help you easily solve these problems. The following is the key features of remove software mac 1.All-in-one utility It can clear all the cache which is stay in your Mac computer .What you have to do is press button. 2.To clear plug-in to release disk space Clear cache for Mac software easily erase all the plug-in that stay in your disk space. To finish this just need some simply click. 3.To improve the storage space It can access the hidden storage area to clear some widget to improve storage environment. 4.Clean up the portable device Keep your removable device free from those annoying and unnecessary service files. 5.Clear the system cache and cookies and folder cache One of the best features of clear cache for Mac is its ability to easily clear the system cache and cookies and folder cache that affect your computer system. 6.Safe to operate in your Mac computer The clear cache for Mac is a safe software ,it don’t have the write-perform function when it runs in your Mac computer. 7.Optimize the computer system It can improve the Mac computer environment through clear the cache and widget. 8.Easy to use Clear cache for Mac software makes system maintenance simple with an easy point .with the simple click ,novice can easy to use to keep the system running at its best. 1.All-in-one utility It can clear all the cache which is stay in your Mac computer .What you have to do is press button. 9.multifunctional feature it can capture the pesky bug when new software operated. How to removing software from mac http://www.umacos.com/images/cleanmac/cleanmac.jpg You can removing software from mac by following steps Instructions Step 1 Confirm that the application you wish to remove does not have an uninstaller. If it does, run the uninstaller to properly remove the application. Step 2 Open your "Applications" folder and find the application you wish to remove. Step 3 Drag the application and any associated folders into the trash. Step 4 Open your Home folder, then go into the Library sub-folder and open the Preferences folder to determine if there are preferences files that need to be removed. If you find files or folders with the same name as the application you want to remove, drag them to the trash. Step 5 Open your Home folder, then go into the Library sub-folder and open the Application Support folder to determine if there are support files that need to be removed. If you find files or folders with the same name as the application you wish to erase, drag them to the trash. Step 6 Drag the Application's icon off the dock with your mouse to remove it from the dock if it is present. Step 7 Right-click on the Trash on the dock and select "Empty Trash" to fully remove the files you have dragged there. Related articles mac search results clearing mac permanently delete console messages clearing clear previous searches on macbook |
