Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 10-29-2010, 03:17   #1 (permalink)
Member: 1429470
Sonork: 624369049
How to Erase Software for Mac?
uninstall software mac with software removal on mac!
Why should we uninstall software mac?
We usually use the computer in the process, often install some software, but some software may use the frequency is very low, or no longer used once or twice, used, regularly delete unused software can save disk space and improve the system efficiency.
removing software for mac is advanced and professional software which designed for Mac user to clearing software on mac
Now many computer users due to work and had to download some office software, but not to long-term use of these software, so removing software from mac can help you easily solve these problems.
The following is the key features of remove software mac
1.All-in-one utility
It can clear all the cache which is stay in your Mac computer .What you have to do is press button.
2.To clear plug-in to release disk space
Clear cache for Mac software easily erase all the plug-in that stay in your disk space. To finish this just need some simply click.
3.To improve the storage space
It can access the hidden storage area to clear some widget to improve storage environment.
4.Clean up the portable device
Keep your removable device free from those annoying and unnecessary service files.
5.Clear the system cache and cookies and folder cache
One of the best features of clear cache for Mac is its ability to easily clear the system cache and cookies and folder cache that affect your computer system.
6.Safe to operate in your Mac computer
The clear cache for Mac is a safe software ,it donít have the write-perform function when it runs in your Mac computer.
7.Optimize the computer system
It can improve the Mac computer environment through clear the cache and widget.
8.Easy to use
Clear cache for Mac software makes system maintenance simple with an easy point .with the simple click ,novice can easy to use to keep the system running at its best.
9.multifunctional feature
it can capture the pesky bug when new software operated.
How to removing software from mac
You can removing software from mac by following steps
Instructions
Step 1
Confirm that the application you wish to remove does not have an uninstaller. If it does, run the uninstaller to properly remove the application.
Step 2
Open your "Applications" folder and find the application you wish to remove.
Step 3
Drag the application and any associated folders into the trash.
Step 4
Open your Home folder, then go into the Library sub-folder and open the Preferences folder to determine if there are preferences files that need to be removed. If you find files or folders with the same name as the application you want to remove, drag them to the trash.
Step 5
Open your Home folder, then go into the Library sub-folder and open the Application Support folder to determine if there are support files that need to be removed. If you find files or folders with the same name as the application you wish to erase, drag them to the trash.
Step 6
Drag the Application's icon off the dock with your mouse to remove it from the dock if it is present.
Step 7
Right-click on the Trash on the dock and select "Empty Trash" to fully remove the files you have dragged there.
Related articles
mac search results clearing
mac permanently delete console messages clearing
clear previous searches on macbook
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Page generated in 0.24608 seconds with 8 queries
