04-02-2015, 21:14 | #2 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2366267 Status: Offline Thanks Meter: 1 | The Teamviewer ID is based on the en0 or en1 (not quite sure) MAC Adress. If you clone your system to another HD, the ID remains the same! Also happens, when you do a restore with Time Machine. Solution: Uninstall Teamviewer with the Uninstaller, or use a good freeware App, called: AppCleaner (you can find this on macupdate . com) Then reboot your mac. Install TeamViewer again now! If the ID doesn't change - do the same with your other Mac! First try to change the ID on the "newer" machine, which took the ID from the older! |
