How to reset password on macbook air need to reset macbook air password, tried this command : Cmd + R or S, but still asking also a password. a n trick to remove it easily ? any help |
2. Hold apple key + s key down after you hear the chime. (command + s keys on newer Macs) 3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line): mount -uw / rm /var/db/.AppleSetupDone shutdown -h now 4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again! |
i said when i try those commands, it gives a menu asking a password too with a cadenas locked above. Quote:
that means there is a password on yr bois, you need to flash yr motherboard, |
how to flash it ? reinstalling the os ? Quote:
and flashing yr logic board, is hardware work, I don't think yr able to do it BUT try those steps 1- try to exchange yr ram with different ram and then try those commands y tried 2- if u have 4g ram for ex, try to put only 2g ram and try yr command if none of those doesn't work send me image of the screen u getting |
on macbook air the ram are soldered on mainboard. Quote:
what macbook air? is the password you want to reset a efi password? |
how much chances is there to reset the bios password |
@nirav. I think he has an EFI password (firmware pass). This is hard to remove on macbook air ( even the exchange or remove of Ram wont work). Only way to do this is to take out the bios chip out and solder an new one on it. Not an easy task to do.... |
according to my info : There is facility to setup a bios passcode in macbook air. This is probably the administrative password . So for admin pass you need a installX OS dvd* Boot from the Mac OS X installer disk by inserting it into the Mac and holding down the “C” key on boot Select your language preferences and then under the “Utilities” menu select “Password Reset” (it may say “Reset Password” instead, depends on the version of Mac OS X) Select the hard disk that the forgotten password is on, then select the username of the forgotten password, you’ll then be asked to select a new password Reboot as usual from the hard drive, using your newly reset password as the login! :) GSM-DOCTOR |
You can use USB DVD Drive because Air don't have CD/DVD Drive |
GUYSSSSSSSSSSS, Please stop confusing the guy !!!!!!!!!! commands R and S will not work in bios password, only way to do it, is by flashing yr lojic board, which i doubt any can do that, unless its APPLE engineers GUYS( Genius ones too) 2- If you bought legally this mac book air, i recommend you take it to nearest apple store they will fix it for u most of those macbooks with bios pass, are illegal in another word are stolen or what ever, |
yer well i had this machine and i did this because he wouldn't pay me for doing a job great fun for me it was |
sorry wasn't me i did it on a mack book pro not a mac book air |
