Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 05-24-2017, 17:05   #1 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
How to Restore Macbook from USB need help
i have imac i download your file on my laptop not on imac and copy to usb device now how i flah my imac my imac is formatted and only access to restore menu so how to mac this usb flash able using laptop windows 8
Old 05-24-2017, 17:27   #2 (permalink)
wahidsam's Avatar
Member: 46191
Thanks Meter: 30
Hi
You have to partition your USB disk to GPT first, then burn MAC OS DMG file on it using Transmac on windows.
Follow the full guide on this link How to quickly make a Mac OS X bootable USB on Windows ? PUREinfoTech
Good luck
Old 05-27-2017, 00:10   #3 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
hello
the easyest method i prefer and i use for every mac
you need diskmaker X+ iso of macosx
Create diskmaker X with an another Mac
press an hold Option (⌥) key at startup
and select USB key
that s all
The Following User Says Thank You to kham For This Useful Post:
Old 05-27-2017, 19:32   #4 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
Originally Posted by wahidsam View Post
Hi
Good luck
Thanks for your replay i successfully create and and install but still not boot to normal mode i it cant show me startup disc when i try to select startup disk there is nothing show on startup disc any help
Old 05-28-2017, 10:46   #5 (permalink)
wahidsam's Avatar
Member: 46191
Thanks Meter: 30
Hi
Is your HDD a brand new, you have to make it GPT also and format it as HFS+, just search on the net for formating HDD to MAC OS partition table.
It may be due to your OS image too, just download an other one with DMG extension and repeat the process of burning.
I'll try to find some direct links to guide you.
BR.
Old 05-28-2017, 11:59   #6 (permalink)
wahidsam's Avatar
Member: 46191
Thanks Meter: 30
Hi
BR.
Hi
Here is a link to show you how to prepare your HDD for MAC OS system on windows machine.
How to Format a Disk to HFS Without a Mac | Chron.com
Could you share your MAC machine specifications ?
Type, model, production year....
Also, are you holding ALT button when booting your Mac, you should do it in order to install MAC OS from USB disk to your HDD Mac machine.
BR.
Old 05-28-2017, 13:13   #7 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
Hi
BR.
thanks for your help i am going to check it then i will tell you
Old 05-29-2017, 08:32   #8 (permalink)
Member: 2721831
Originally Posted by kham View Post
hello
and select USB key
that s all
Thanks, that was really helpful.
Old 05-29-2017, 15:42   #9 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
boot with usb key (make with diskmaker X)
don t lauch installation
go to disk utility
format the new hard drive
return
now install macosx
you will see your new drive
Old 07-04-2017, 20:13   #10 (permalink)
Member: 2012453
go to disk utility
return
now install macosx
Hello, correct me if im wrong. Is this diskmaker X not only for OSX. Or is ther a windows version of it to boot Osx frm usb.
The Following User Says Thank You to Squizy-V For This Useful Post:
Page generated in 0.22315 seconds with 8 queries
