05-24-2017, 17:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | How to Restore Macbook from USB need help |
05-24-2017, 17:27 | #2 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: ALGERIA Age: 45
Member: 46191 Status: Offline Thanks Meter: 30 | Quote:
You have to partition your USB disk to GPT first, then burn MAC OS DMG file on it using Transmac on windows. Follow the full guide on this link How to quickly make a Mac OS X bootable USB on Windows ? PUREinfoTech Good luck | |
05-27-2017, 00:10 | #3 (permalink) |
No Life Poster Join Date: Jan 2001 Location: France/Martinica/CPU Age: 45
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | hello the easyest method i prefer and i use for every mac you need diskmaker X+ iso of macosx Create diskmaker X with an another Mac press an hold Option (⌥) key at startup and select USB key that s all |
The Following User Says Thank You to kham For This Useful Post: |
05-27-2017, 19:32 | #4 (permalink) | |
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | Quote:
05-28-2017, 10:46 | #5 (permalink) | |
Is your HDD a brand new, you have to make it GPT also and format it as HFS+, just search on the net for formating HDD to MAC OS partition table. It may be due to your OS image too, just download an other one with DMG extension and repeat the process of burning. I'll try to find some direct links to guide you. BR. Last edited by wahidsam; 05-28-2017 at 10:47. Reason: Add information | |
05-28-2017, 11:59 | #6 (permalink) | |
Here is a link to show you how to prepare your HDD for MAC OS system on windows machine. How to Format a Disk to HFS Without a Mac | Chron.com Could you share your MAC machine specifications ? Type, model, production year.... Also, are you holding ALT button when booting your Mac, you should do it in order to install MAC OS from USB disk to your HDD Mac machine. BR. Last edited by wahidsam; 05-28-2017 at 12:02. Reason: add info | |
05-28-2017, 13:13 | #7 (permalink) | |
07-04-2017, 20:13 | #10 (permalink) |
Junior Member Join Date: Aug 2013 Location: Douala, Cameroon
Member: 2012453 Status: Offline Thanks Meter: 1 | Hello, correct me if im wrong. Is this diskmaker X not only for OSX. Or is ther a windows version of it to boot Osx frm usb. |
The Following User Says Thank You to Squizy-V For This Useful Post: |
