Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 08-04-2018, 15:09   #1 (permalink)
Member: 592800
iMac A-1311 820-3126-A Wont turn on
Hello guys,
I have one iMac A-1311 and it won't turn on. In the board, the LED's won't turn on either. I change the A/C power supply and don't solve the problem.
Old 08-31-2018, 13:58   #2 (permalink)
Member: 2854895
if theres no led then sounds like theres a board level component shorted in which you would need to test or could be a dry solder joint. check caps for bad solder joints.
Old 12-22-2018, 15:38   #3 (permalink)
Member: 2729682
Thanks Meter: 5
Did you open it up and check that the connections to the power supply socket are fine, it could be the on/off switch also
Page generated in 0.17544 seconds with 7 queries
