Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 01-16-2016, 22:34   #1 (permalink)
Member: 2471075
reset password on macbook pro A1286
please help i need to reset pin code macbook pro (15-inch, Early 2011) (CTO)
Old 01-17-2016, 01:07   #2 (permalink)
Moderator
sebagsm's Avatar
Member: 15994
Thanks Meter: 263
do a nvram reset:
1. Shut down your Mac.
2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
3.Turn on your Mac.
4. Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
5.Hold these keys until the computer restarts and you hear the startup sound for a second time.
6.Release the keys.
The Following User Says Thank You to sebagsm For This Useful Post:
Old 01-17-2016, 11:00   #3 (permalink)
Member: 2471075
i tried but it doesn't work so please any other solution
Old 01-17-2016, 12:28   #4 (permalink)
Moderator
sebagsm's Avatar
Member: 15994
Thanks Meter: 263
then you need to dump the efi .. and send me the that dump
Old 01-17-2016, 16:26   #5 (permalink)
Member: 2471075
please how i dump the efi... and if i put all the probabilities of number it's a pin of 4 number it means 10000 code is that good idea remove that pin
Old 01-17-2016, 22:55   #6 (permalink)
Member: 2471075
please any other idea
Old 01-26-2016, 22:58   #7 (permalink)
Member: 463420
Thanks Meter: 150
If you can't handle the professional way or at least deep google search> We can always contact my Grandma to double check the numbers for your Mac and the lottery.
The last one worked for me ))
Btw because of moonlight this weekend you can get up to 50% discount!
Kimov
Regards
Old 01-29-2016, 23:27   #8 (permalink)
Member: 2523680
Thanks Meter: 2
1. Reboot
2. Hold apple key + s key down after you hear the chime.
(command + s keys on newer Macs)
3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again!
Old 02-10-2016, 11:44   #9 (permalink)
Member: 2277735
Thanks Meter: 215
If not remove hdd, mount hdd using transmac in windows and then get elf or passcode from correct file!
Old 02-19-2016, 18:20   #10 (permalink)
MichieMax's Avatar
Member: 40758
Thanks Meter: 26
Hi Buddys i have a MacBook Pro 2009 its asking for a pin lock have tryd to reset it with all the tricks here with no luck i have dumped the file its 4mb the chips on it is MX chip 25L3205DM2I any idea to reset will be appreciated
Old 03-06-2016, 10:02   #11 (permalink)
Member: 1298516
Thanks Meter: 14
send me the dump if you still need help
Old 05-17-2016, 13:44   #12 (permalink)
Member: 1738539
Thanks Meter: 11
For the iMac,iPhone ,Android device,please try our toold HDBox.
Products | HDB Team
Old 06-15-2016, 20:16   #13 (permalink)
Member: 2219780
Sonork: 100.1662738
Thanks Meter: 52
you have two ram in your lap top remove one of them and boot your device
create new password from firmware password utility
put your ram again boot with the new password
you can remove it
sorry for my bad english
Old 08-30-2016, 13:06   #14 (permalink)
Member: 1798661
Sonork: 1669055
Thanks Meter: 110
you can unlock with remove icloud S/N in 1H
Old 08-31-2016, 03:11   #15 (permalink)
epidemija's Avatar
Member: 1869239
Thanks Meter: 53
Unlock with S/N will not remove efi lock!
Page generated in 0.21678 seconds with 8 queries
