10-24-2017, 12:41 | #1 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2771295 Status: Offline Thanks Meter: 0 | Macbook Air 11" Mid 2011 - Unable to dump the EFI I'm using a 1.500 mA micro-USB power supply and the adapter is connected to the pi with 10 cm cables I have conneted (Adapter to Header Pin) 3.3V -------> 17 SLCK-------> 23 SI----------> 19 GND-------> 25 SO---------> 21 CS---------> 24 But I can not read the EFI. I'm using flashrom v0.9.9-r1954 on Linux 4.9.41+ (armv6l) (Raspbian) ____ flashrom -p linux_spi:dev=/dev/spidev0.0 No EEPROM/flash device found. ____ I have tried: - The switch on the Connector to the left and right - Battery and Magsafe connected to the Macbook - Battery and Magsafe disconnected - Battery disconnecte - Macsafe conneted - Only wit the Battery connected but it doesn't work. Any idea, what could be wrong? Unfortunately I can not post pictures of my setup ... You need 10 Post ... even to include Pictures in a Thread. |
10-24-2017, 15:36 | #2 (permalink) |
Member: 2771295 Status: Offline Thanks Meter: 0 | Edit: Some further information (but I don't understand it) I have found this on the rebelsimcard site: ---- For models A1398 - A1369 - A1370 switch to the right. ---- ok ... I must switch to the right position. No problem. ---- Use the 3.3v for the WP and the HOLD from pin 8 or from external Power Source ---- This adapter has no WP and HOLD. It has only 6 connectors. |
10-27-2017, 08:53 | #4 (permalink) |
Member: 2771295 Status: Offline Thanks Meter: 0 | This adapter is useless, if you have a Macbook Air 11" 2011 (1370). WP and HOLD are on the backside of the logic board. So I have to: - remove the logic board - solder a cable to the WP and HOLD pins and connect them to 3.3 V Removing the board is quite easy, but soldering cables to the tiny connetors is to much for me. Let's see what "Remove EFi with SN+HASH" means. I guess there is a decription here in the forum. Will try to find it. Thank you for the hint. |
10-27-2017, 10:11 | #5 (permalink) |
Member: 2771295 Status: Offline Thanks Meter: 0 | I still can not post links. If you google for: "Apple EFI firmware passwords and the SCBO myth" you will find a description. Seems to be easy. I only need the Hash (Control-Option-Command-Shift-S), the serial number on the Logic Board and a "clean" SCBO. Step 1 --------- Get the Hash (Control-Option-Command-Shift-S) --------- Step 2 Get the serial number. I have opend the Air, but I can't find it. Maybe it is on the backside of the Logic Board. Google will tell me. -------- Step 3 I have to change the serial number in the clean SCBO to my serial number. (Not shure about this .. I don't use iCloud ... has the serial number in the SCBO to match the serial number on the Logic Board?) ------- Step 4 This file can be "flashed" with a USB stick. ------ Step 5 Clear the NVRAM (alt+cmd+P+S) ----- Step 6 Install MacOS ----- I have to check my bookmarks. There was a site with SCBOs for all kind of Macbooks. Wow ... no Adapter needed .... no soldering ... and easy to do it again without opening the Macbook again (If I write down the serial number). Really ... that's all???? |
10-28-2017, 10:26 | #6 (permalink) |
Member: 2771295 Status: Offline Thanks Meter: 0 | The "Remove EFi with SN+HASH" means, that I have to pay 100 - 150 $ and it is a "one shot"? Fair for an expensive device like a new Air or a Macbook Pro ... but for an old (2010) Air ... to much. Soldering cables to the connetors on the backside of the Logic Board (by a professional electronics) would cost about 20 $. Reading my EFI with the adapter... one step further. When I connect the adapter to my Macbook (battery at 100% and magsafe conneted): ---- Calibrating delay loop... OK. Found Generic flash chip "unknown SPI chip (RDID)" (0 kB, SPI) on linux_spi. ---- So flashrom was able to find the IC, but can not read it. Seems to be a power problem. That means: - Cables to long or to thin (10 cm at the moment) - The 1.500 mA power supply is not strong enough - One ore more Jumper Wires are on the wrong raspberry pin btw ... I was wrong ... The Macbook Air ist not a 2011 model. It is a "Late 2010". I still don't know, where I can find the serial number of the Logic Board. Maybe it is on the backside. I have found a (almost) clean SCBO in a thread here and a locked one. At the moment I playing with some emulators that can run EFI binaries and I have IDA Pro + some plugins to disassemble and analyse EFI code. |
