01-28-2012, 01:27 | #16 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1158416 Status: Offline Thanks Meter: 182 | Try the hardware tricks to bypass firmware password. 1) Shut down your macbook 2) Remove Battery and RAM 3) Put battery back and Boot up the computer while holding COMMAND+OPTION+P+R (boot up w/o RAM,this resets the parameter ram) 4) Wait for the startup chime to sound 3 times 5) Release the keys and shutdown the machine, once you reach the login screen 6) Remove Battery again and put the RAM and battery back. 7) Now if you boot up the machine you should bypass the Mac firmware password. Last edited by analot; 01-28-2012 at 01:32. |
01-28-2012, 04:49 | #17 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Philippines Age: 36
Member: 758106 Status: Offline Sonork: jap_line Thanks Meter: 412 | Quote:
but its hard to find the star tool to remove the screw. (MacBook Air 5-Point Pentalobe Screwdriver) tools for iphone 4 is not working. btw, ill post result Br. | |
01-28-2012, 05:50 | #18 (permalink) | |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
if you open you will find that the RAM module is soldered onto board | |
The Following User Says Thank You to Gecko_UK For This Useful Post: |
01-28-2012, 17:48 | #19 (permalink) | |
Junior Member Join Date: Nov 2010
Member: 1451074 Status: Offline Thanks Meter: 3 | Quote:
sorry brother i will give u and idea but it's on your risk plus need a prof. to do it try to remove the ram and do the ram trick than resolder not tested but i guess it will solve it | |
The Following User Says Thank You to the_pharo For This Useful Post: |
01-30-2012, 00:50 | #21 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | Yep, you don't keep pressed the Option key(ALT) for booting from the USB key lol... Sorry for the late reply , just seen your PM.But give me your yahoo if you have and I will help you in deep ..... br, free1600 |
The Following User Says Thank You to free1600 For This Useful Post: |
01-30-2012, 02:41 | #22 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Tsambakol team house Age: 38
Member: 737818 Status: Offline Thanks Meter: 228 | if above solution bot work; final option: take it out the hard drive and do Format on it................ after formatting load Mac OS using flash drive..... the hard drive inside is a SATA type correct me if i'm wrong note: mahirap tanggalin ang screw niyan at madali pang ma lose thread |
The Following User Says Thank You to johnric For This Useful Post: |
01-30-2012, 02:56 | #23 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Cavite, Philippines Age: 43
Member: 139251 Status: Offline Thanks Meter: 16 | Kabayan contact mo yung classmate ko na dating software engineer sa Apple Philippines, freelance na sya ngayon. ito ang contact nya: Jeross-09192644882 Last edited by enrikez; 01-30-2012 at 03:04. |
The Following User Says Thank You to enrikez For This Useful Post: |
02-15-2012, 09:23 | #25 (permalink) | ||
btw, thanks for your ideas and guides. still searching for other solution WHAT NOW Br. | ||
02-20-2012, 05:17 | #26 (permalink) | |
i'm just curious, btw, thanks for this great idea. Br. | |
02-26-2012, 11:21 | #27 (permalink) |
Insane Poster Join Date: May 2003 Location: Latvia, Riga Age: 41
Member: 28936 Status: Offline Thanks Meter: 0 | efi psw I put SSD disk from locked air to other air, formated drive and install fresh lion on it. Put it back and now i have air with question screen. So clean install doesn't work with firmware password. I try to use same names on partitions and it won't boot anyway. So i'm stuck. I'm wondering, how firmware check for right partition? Is it checking prom hard drive EFI partition or there is something else? How do apple remove firmware password? |
04-23-2012, 07:37 | #28 (permalink) |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | MacBook Air Late 2010 Hello I have a MacBook Air Late 2010, just like the one from this thread, and with OS : 10.7.2, and Firmware Password when booting with ALT, or CMS + S, or CMD + R, etc. there's an admin account on the laptop, there's no password when starting, i can use it. i would like to create a NEW ADMIN account and remove the OLD ONE, but i DO NOT have the old password ( forgot it ). is there a way to install a fresh OS from scratch ? or to remove the old admin ? thanks PS : methods from ******** . com - NOT Woking |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
