MacBook Air Late 2010 Model USER and PASSWORD PROBLEM good day! looking for mac specialist or hacker maybe. i have a MacBook Air here Late 2010 model, the problem is the USER and PASSWORD. we don't have the original disk or anything ONLY THE UNIT and CHARGER. we're trying to enter Startup Manager, Sigle user mode, Verbose mode. etc. etc. but evern Startup Manager has PASSWORD. and the rest, key combinations are also not working, i think it was DISABLE. http://i1096.photobucket.com/albums/...ombination.jpg is there any other way to hack or to bypass this and reset the password with this situation? i will really appriciate for help. Br. |
u need a clean restore from a usb flash download the last mac lion on other mac and restore it on the usb flash than put it on ur macair than start a clean restore |
Agree ! In the new models without CD drive you can hold the ALT key and power on. Then you will get in the restore screen. You can erase the old data and start from scratch again. |
hold down cmd+S (⌘S) on startup and type following command: mount -uw / rm /var/db/.AppleSetupDone shutdown -h now power on your macbook and follow the following procedure to create new account. personally tested on macbook G4, Macbook Pro and Macbook white |
it will just boot to normal mode, and welcome screen and then ask USER and PASSWORD. and when i tried to hold ALT + power, it will show PADLOCK icon and asking for PASSWORD again. add me pls , YM kabayan :) i'm willing to bring the unit, or visit your shop and pay your service, just to fix this problem. YM account: [email protected] THANK YOU VERY MUCH! Br. |
doesn`t matter if its late or new or very old model! if it is late OS Lion, you need Recover Image, if OS is older you can use method described in previous post |
No disk Snow Leopard http://www.trickyways.com/2010/06/fo...-without-disk/ simple done on several snow leopards Cheers |
IF THE FIRST STEP OF THE PROCEDURE IS TO ENTER STARTUP MODE (CMD+S) IS NOT WORKING, HOW CAN I PROCEED.???? IS THERE ANY OTHER WAY? CMD+S = NOT WORKING CMD+V = NOT WORKING ALT(OPTION) = NOT WORKING Br. |
1 get your self an 8GB usb flash 2 get other macbook and restore the dmg image of mac lion on it using the disk utility 3 put the usb flash and while u power ur mac on hold the alt key and u will get a screen show u ur hard drive and ur flash and choose to boot from flash and flow the screen to get a clean restore if it hard for u second choose is find a dmg dvd for lion get an external usb dvd and plug it into ur mac and do the alt key thing or just press the c key that the only 2 solution u have check that video may help you http://www.youtube.com/watch?v=XMJEwBzMQKs |
Yes :) 1.Take a 8GB USB Key and install Lion dmg on it.(use windows it will take you 15 min to create the usb key) 2.Keep ALT when you hear the mac doing . 3.Choose the USB Thumb with Lion and start on it. 4.Do your job...Better Format and install a proper Lion OS. Voila Good Luck. br, free1600 |
i have os lion already, and make it bootable with two drive, USB FDD and USB HDD. but STILL NO LUCK! and just end up with this LOCKED menu (PLEASE WATCH THE VIDEO I CREATE SO YOU CAN VIEW THE STATUS OF THE MAC) MacBook Air Late 2010 Password Problem! - YouTube is there anymore chance? THANKS. Br. |
that is firmware password i have here 2 macbook pro same problem cant find sollution and trick reset nvram dont work since 2010 models |
hoping a angel from apple share the solution for this problem Br. |
if you have something like this or a spare macbook you can remove password: take out ssd, enable EFI shell and use dmpstore cmd to clear.. or if you just want to remove user account password copy this file myuser.plist. and use DaveGrohl.org / JTR to crack and then proceed from there |
macos Hy I buy one macbook used and the old owner instal one hd with windows xp... Now i change the HD and put mac os x but some programs not work. How can i change to mac osx lion? is possible? Thanks BR |
