Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 01-11-2012, 09:44   #1 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
MacBook Air Late 2010 Model USER and PASSWORD PROBLEM
good day!
looking for mac specialist or hacker maybe.
i have a MacBook Air here Late 2010 model,
the problem is the USER and PASSWORD.
we don't have the original disk or anything ONLY THE UNIT and CHARGER.
we're trying to enter Startup Manager, Sigle user mode, Verbose mode.
etc. etc.
but evern Startup Manager has PASSWORD.
and the rest, key combinations are also not working, i think it was DISABLE.
is there any other way to hack or to bypass this and reset the password
with this situation?
i will really appriciate for help.
Br.
Old 01-11-2012, 12:16   #2 (permalink)
Member: 1451074
Thanks Meter: 3
u need a clean restore from a usb flash download the last mac lion on other mac and restore it on the usb flash than put it on ur macair than start a clean restore
Old 01-11-2012, 12:56   #3 (permalink)
Member: 1583294
Thanks Meter: 27
Agree !
In the new models without CD drive you can hold the ALT key and power on.
Then you will get in the restore screen.
You can erase the old data and start from scratch again.
The Following User Says Thank You to X10robin For This Useful Post:
Old 01-11-2012, 15:25   #4 (permalink)
Member: 1158416
Thanks Meter: 182
hold down cmd+S (⌘S) on startup
and type following command:
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
power on your macbook and follow the following procedure to create new account.
personally tested on macbook G4, Macbook Pro and Macbook white
The Following User Says Thank You to analot For This Useful Post:
Old 01-15-2012, 15:40   #5 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
mount -uw /
shutdown -h now
i tried this already but when i hold CMD+S on startup, nothings happen.
it will just boot to normal mode, and welcome screen and then ask USER and PASSWORD.
and when i tried to hold ALT + power, it will show PADLOCK icon and asking for PASSWORD again.
add me pls , YM kabayan
i'm willing to bring the unit, or visit your shop and pay your service, just to fix this problem.
YM account: [email protected]
THANK YOU VERY MUCH!
Br.
Old 01-15-2012, 17:03   #6 (permalink)
Member: 15184
Thanks Meter: 4
doesn`t matter if its late or new or very old model!
if it is late OS Lion, you need Recover Image, if OS is older you can use method described in previous post
The Following User Says Thank You to tito2002 For This Useful Post:
Old 01-15-2012, 17:38   #7 (permalink)
darksman's Avatar
Member: 849979
Sonork: 100.1603463
Thanks Meter: 923
No disk Snow Leopard
http://www.trickyways.com/2010/06/fo...-without-disk/
simple done on several snow leopards
Cheers
The Following 3 Users Say Thank You to darksman For This Useful Post:
Old 01-16-2012, 05:25   #8 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
Forgot Mac Password? See how to Reset Without Disk | Mac OS X
Cheers
I ALREADY SAID TWICE, CMD+S COMMAND IS NOT WORKING HERE.
IF THE FIRST STEP OF THE PROCEDURE IS TO ENTER STARTUP MODE (CMD+S) IS NOT WORKING, HOW CAN I PROCEED.????
IS THERE ANY OTHER WAY?
CMD+S = NOT WORKING
CMD+V = NOT WORKING
ALT(OPTION) = NOT WORKING
Br.
Old 01-16-2012, 11:19   #9 (permalink)
Member: 1451074
Thanks Meter: 3
CMD+S = NOT WORKING
CMD+V = NOT WORKING
Br.
my friend this method if work it will only give u other account that allow you to get some advance but to clear the password did what i told u
1 get your self an 8GB usb flash
2 get other macbook and restore the dmg image of mac lion on it using the disk
utility
3 put the usb flash and while u power ur mac on hold the alt key and u will get a screen show u ur hard drive and ur flash and choose to boot from flash and flow the screen to get a clean restore
if it hard for u second choose is find a dmg dvd for lion
get an external usb dvd and plug it into ur mac and do the alt key thing or just press the c key
that the only 2 solution u have
check that video may help you
http://www.youtube.com/watch?v=XMJEwBzMQKs
The Following User Says Thank You to the_pharo For This Useful Post:
Old 01-16-2012, 12:11   #10 (permalink)
free1600's Avatar
Member: 467911
Thanks Meter: 351
Yes
1.Take a 8GB USB Key and install Lion dmg on it.(use windows it will take you 15 min to create the usb key)
2.Keep ALT when you hear the mac doing .
3.Choose the USB Thumb with Lion and start on it.
4.Do your job...Better Format and install a proper Lion OS.
Voila Good Luck.
br,
free1600
The Following User Says Thank You to free1600 For This Useful Post:
Old 01-27-2012, 17:10   #11 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
utility
Installing Mac OS Lion beta on a 2010 Macbook Air with a USB Flash drive - YouTube
Originally Posted by free1600 View Post
Yes
Voila Good Luck.
br,
free1600
this is what i mean.
i have os lion already, and make it bootable with two drive, USB FDD and USB HDD.
but STILL NO LUCK!
and just end up with this LOCKED menu
(PLEASE WATCH THE VIDEO I CREATE SO YOU CAN VIEW THE STATUS OF THE MAC)
MacBook Air Late 2010 Password Problem! - YouTube
is there anymore chance?
THANKS.
Br.
Old 01-27-2012, 17:14   #12 (permalink)
ChelasGsm's Avatar
Member: 12966
Thanks Meter: 133
that is firmware password i have here 2 macbook pro same problem cant find sollution and trick reset nvram dont work since 2010 models
The Following User Says Thank You to ChelasGsm For This Useful Post:
Old 01-27-2012, 18:56   #13 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
hoping a angel from apple share the solution for this problem
Br.
Old 01-27-2012, 20:08   #14 (permalink)
Gecko_UK's Avatar
Member: 961957
Sonork: Jabber: [email protected]
Thanks Meter: 641
Yes on new macbook air, when you take to Apple to reset firmware password, they get hash (see when you setup with setregproptool ) and generate password from there
if you have something like this or a spare macbook you can remove password: take out ssd, enable EFI shell and use dmpstore cmd to clear.. or if you just want to remove user account password copy this file myuser.plist. and use DaveGrohl.org / JTR to crack and then proceed from there
The Following User Says Thank You to Gecko_UK For This Useful Post:
Old 01-27-2012, 20:11   #15 (permalink)
zipikiki's Avatar
Member: 85182
Sonork: 1593854
Thanks Meter: 42
macos
Hy
I buy one macbook used and the old owner instal one hd with windows xp... Now i change the HD and put mac os x but some programs not work. How can i change to mac osx lion? is possible?
Thanks
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.32024 seconds with 10 queries
