Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 01-28-2012, 00:27   #16 (permalink)
Member: 1158416
Thanks Meter: 182
It's a Firmware Password bro.
Try the hardware tricks to bypass firmware password.
1) Shut down your macbook
2) Remove Battery and RAM
3) Put battery back and Boot up the computer while holding COMMAND+OPTION+P+R (boot up w/o RAM,this resets the parameter ram)
4) Wait for the startup chime to sound 3 times
5) Release the keys and shutdown the machine, once you reach the login screen
6) Remove Battery again and put the RAM and battery back.
7) Now if you boot up the machine you should bypass the Mac firmware password.
The Following 2 Users Say Thank You to analot For This Useful Post:
Old 01-28-2012, 03:49   #17 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
big thanks, i will try this solution today.
but its hard to find the star tool to remove the screw.
(MacBook Air 5-Point Pentalobe Screwdriver)
tools for iphone 4 is not working.
btw,
ill post result
Br.
Old 01-28-2012, 04:50   #18 (permalink)
Gecko_UK's Avatar
Member: 961957
Sonork: Jabber: [email protected]
Thanks Meter: 639
This method is tested and working on macbook pro and prior series to remove firmware password.. Unfortunately (as mentioned before) this does not work for macbook air
if you open you will find that the RAM module is soldered onto board
The Following User Says Thank You to Gecko_UK For This Useful Post:
Old 01-28-2012, 16:48   #19 (permalink)
Member: 1451074
Thanks Meter: 3
it's true the ram is on soldered on board only apple can help
sorry brother
i will give u and idea but it's on your risk plus need a prof. to do it
try to remove the ram and do the ram trick than resolder
not tested but i guess it will solve it
The Following User Says Thank You to the_pharo For This Useful Post:
Old 01-28-2012, 17:39   #20 (permalink)
Member: 962155
Restart with the Option key held down, tab to the recovery drive, press Enter, and use that
Old 01-29-2012, 23:50   #21 (permalink)
free1600's Avatar
Member: 467911
Thanks Meter: 349
Yep, you don't keep pressed the Option key(ALT) for booting from the USB key lol...
Sorry for the late reply , just seen your PM.But give me your yahoo if you have and I will help you in deep .....
br,
free1600
The Following User Says Thank You to free1600 For This Useful Post:
Old 01-30-2012, 01:41   #22 (permalink)
Member: 737818
Thanks Meter: 218
if above solution bot work;
final option:
take it out the hard drive and do Format on it................
after formatting load Mac OS using flash drive.....
the hard drive inside is a SATA type
correct me if i'm wrong
note: mahirap tanggalin ang screw niyan at madali pang ma lose thread
The Following User Says Thank You to johnric For This Useful Post:
Old 01-30-2012, 01:56   #23 (permalink)
Member: 139251
Thanks Meter: 16
Kabayan contact mo yung classmate ko na dating software engineer sa Apple Philippines, freelance na sya ngayon. ito ang contact nya: Jeross-09192644882
The Following User Says Thank You to enrikez For This Useful Post:
Old 02-10-2012, 22:31   #24 (permalink)
Member: 1715661
Sonork: SONORK
So, i have the same problem, did the pull out the ssd and format it, works???
The Following User Says Thank You to jobbbby For This Useful Post:
Old 02-15-2012, 08:23   #25 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
tried this and other pram nvram reset but still NO LUCK!
final option:
sorry bro, this is not sata type, apple use ssd flash instead of sata hdd for macbook air new models like: 2010 & 2011
btw,
thanks for your ideas and guides.
still searching for other solution
WHAT NOW
Br.
Old 02-20-2012, 04:17   #26 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
OWC Mercury On-The-Go USB 3.0/2.0 External, Bus-Powered Enclosure Solution for Apple MacBook Air 2010 & 2011 Flash Drive (SSD)
to clear EFI in new macbook air you must enable EFI shell then use dmpstore to clear password.. pram reset/ram removal etc does not work anymore
what if i replace ssd? will it work? password will remove?
i'm just curious,
btw,
thanks for this great idea.
Br.
Old 02-26-2012, 10:21   #27 (permalink)
Member: 28936
efi psw
I put SSD disk from locked air to other air, formated drive and install fresh lion on it. Put it back and now i have air with question screen. So clean install doesn't work with firmware password. I try to use same names on partitions and it won't boot anyway. So i'm stuck.
I'm wondering, how firmware check for right partition? Is it checking prom hard drive EFI partition or there is something else?
How do apple remove firmware password?
Old 04-23-2012, 07:37   #28 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 135
Question MacBook Air Late 2010
Hello
I have a MacBook Air Late 2010, just like the one from this thread, and with
OS : 10.7.2, and Firmware Password when booting with ALT, or CMS + S, or CMD + R, etc.
there's an admin account on the laptop, there's no password when starting, i can use it. i would like to create a NEW ADMIN account and remove the OLD ONE, but i DO NOT have the old password ( forgot it ).
is there a way to install a fresh OS from scratch ? or to remove the old admin ?
thanks
PS : methods from ******** . com - NOT Woking
Old 06-27-2012, 15:40   #29 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Which dmpstore flag should do the job?
B.R.
Alkapone
Old 07-06-2012, 23:58   #30 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question Someone can give link to download OSX 10.6????
Someone can give link to download OSX 10.6 and plz tell how to burn it on usb with win xp
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 13:52
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.39920 seconds with 8 queries
