Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 07-12-2012, 06:53   #31 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
after months..
FINALLY!!
PROBLEM SOLVED.
Br.
Old 07-12-2012, 09:18   #32 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 135
How ?
How did you do it ? Is there a software solution ?
Old 07-12-2012, 09:53   #33 (permalink)
Member: 132207
Thanks Meter: 12
Originally Posted by jap_line View Post
i tried this already but when i hold cmd+s on startup, nothings happen.
It will just boot to normal mode, and welcome screen and then ask user and password.
And when i tried to hold alt + power, it will show padlock icon and asking for password again.
Add me pls , ym kabayan
i'm willing to bring the unit, or visit your shop and pay your service, just to fix this problem.
Ym account: [email protected]
thank you very much!
Br.
what about data its washout or not. After this.
Old 07-12-2012, 16:07   #34 (permalink)
Cheater -Don't Deal with him-
Member: 110715
Sonork: -
Thanks Meter: 234
after months..
FINALLY!!
PROBLEM SOLVED.
Br.
how did u solve that ? it is a pay solution ?
Old 07-13-2012, 09:43   #35 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
this is a paid & secret solution as of now.
but you can pm me for those having problem like this, and ill try my best to help you.
Br.
Old 07-13-2012, 11:56   #36 (permalink)
Member: 478535
Thanks Meter: 390
do you mean, this secret?
http://******cityrepair.com/remove-f...d-macbook-air/
step 1. I removed the password bios chip using a professional reflow machine with a large lcd display that you can zoom in on the chip.
step 2  put a new chip in that has firmware on it using infrared soldering. Your are not hostage to apple.
step 3  download the latest firmware update from apple
step 4 turn on machine with new cd in drive and hold the power button until your light blinks rapidly then release it.
step 5 thats it new chip will be loaded with new update firmware and restart like new.
step 6 just added this on june 6 2012 and is very important ….. you must use a blank hard drive and a fresh install of your operating system. If you use your old operating system you run the risk of it auto resetting the firmware password.
or this one?
This chip on macs is manufactured by a company called Atmel and it is visible when you take off the bottom cover of your mac. Atmel chips have been around for years. The process of resetting the password is done in one of two ways. The tech knows how to safely short out the chip thus erasing it and then reloading the firmware downloaded from apple.
Old 07-13-2012, 12:23   #37 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 135
Arrow
step 6 just added this on june 6 2012 and is very important .. you must use a blank hard drive and a fresh install of your operating system. If you use your old operating system you run the risk of it auto resetting the firmware password.
or this one?
ONLY SOLUTIONS !
No other way !
Old 11-28-2012, 17:44   #38 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 129
Hi all
I just unlock my Mac Book Pro with EFI pass .
Im doing some test to check if everithing is OK.
Is not so easy solution ...
baboom
The Following User Says Thank You to baboom For This Useful Post:
Old 11-30-2012, 07:58   #39 (permalink)
Member: 1596475
Sonork: 100.1620950
Thanks Meter: 29
Here's how to reset your OS X password without an OS X CD.
the Working solution for me was to create a new admin
you can create new admin like this by deleting a specific file.
You need to enter terminal and create a new admin account:
1. Reboot
2. Hold apple key + s key down after you hear the chime.
(command + s keys on newer Macs)
3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
The Following User Says Thank You to prakash0055 For This Useful Post:
Old 01-06-2013, 08:53   #40 (permalink)
jap_line's Avatar
Member: 758106
Thanks Meter: 412
TESTED on MACBOOK Pro!
Firmware Password Done..
Br.
The Following User Says Thank You to jap_line For This Useful Post:
Old 01-15-2013, 01:04   #41 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
this is what i mean.
i have os lion already, and make it bootable with two drive, USB FDD and USB HDD.
but STILL NO LUCK!
and just end up with this LOCKED menu
(PLEASE WATCH THE VIDEO I CREATE SO YOU CAN VIEW THE STATUS OF THE MAC)
MacBook Air Late 2010 Password Problem! - YouTube
is there anymore chance?
THANKS.
Br.
if youre on about the efi password and 4 or 6 digit pin, then no software solution can help you, because apart from alt button, then being prompt for password. if you can rovide purchase details then apple will do it for free, if they cant then we have a solution its hardware based, we can reset efi password on all macs, macbook pro and iMacs, made after 2010 ,2011 and 2012
Old 01-15-2013, 01:08   #42 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
tried this and other pram nvram reset but still NO LUCK!
sorry bro, this is not sata type, apple use ssd flash instead of sata hdd for macbook air new models like: 2010 & 2011
btw,
thanks for your ideas and guides.
still searching for other solution
WHAT NOW
Br.
the ram trick wont work on mac made after 2010. check ebay search for mac efi,,there is a solution
Old 01-15-2013, 01:11   #43 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
Originally Posted by darksman View Post
No disk Snow Leopard
Forgot Mac Password? See how to Reset Without Disk | Mac OS X
simple done on several snow leopards
Cheers
does not work on newer macs after 2010, due to efi...and not open firmware
Old 01-15-2013, 01:17   #44 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
Originally Posted by Biezais View Post
I put SSD disk from locked air to other air, formated drive and install fresh lion on it. Put it back and now i have air with question screen. So clean install doesn't work with firmware password. I try to use same names on partitions and it won't boot anyway. So i'm stuck.
I'm wondering, how firmware check for right partition? Is it checking prom hard drive EFI partition or there is something else?
How do apple remove firmware password?
efi fiirmware is stored on a chip on logic board, it holds passwords and iCloud passwords, by installing a fresh hard drive wont clear password on efi chip, thats y you get the folder with question mark......only available solution, check ebay search for mac efi password
Old 01-16-2013, 23:34   #45 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
Originally Posted by johnric View Post
if above solution bot work;
final option:
take it out the hard drive and do Format on it................
after formatting load Mac OS using flash drive.....
the hard drive inside is a SATA type
correct me if i'm wrong
note: mahirap tanggalin ang screw niyan at madali pang ma lose thread
ill correct you fella, on newer machines 2010 plus, old ram trick dont work, also fomatting hard drive in another machine and installing os, then replacing drive wont work either, as the password and pin are stored on logic*board in efi chip, hope this clarifies
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 13:52
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.45808 seconds with 8 queries
