10-08-2016, 22:20 | #1 (permalink) |
Major Poster Join Date: Nov 2011
Member: 1695219 Status: Offline Thanks Meter: 16 | MacBook Pro 8,1 - replacement for r7020 (20mOhm? sensing resistor) it has 4 terminals and I am not successful in finding a replacement by searching with the values given in schematics. Can anyone more experienced help me ? 0.02 0.5% 1W MF 0612-1 |
The Following User Says Thank You to kiezbengel For This Useful Post: |
10-29-2016, 09:05 | #2 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2642557 Status: Offline Thanks Meter: 1 | Hi, in fact you neer a resistor with only 2 terminals. Pins 1 & 3 are connected, so are pins 2 & 4. The easy way to find one is to have it removed from a non working board. |
The Following User Says Thank You to rookieme For This Useful Post: |
11-01-2016, 00:41 | #3 (permalink) |
Member: 1695219 Status: Offline Thanks Meter: 16 | yes,*thanks,*I found that out too. In fact my resistor is fine :-) Wrong beginning after visual inspection only. ( I was just wondering about 4 terminals) do you have some experience with this ? I had a short to GND on PP3V42_G3H and after I attached 3.4 Volts manually to that rail the short on that rail is gone. (without anything ****ing) I think I have more shorts but one step after another I have a short to GND on SMC_BC_ACOK too. I removed Q5310 and U6901. R5078 is a Resistor to PP3V42_G3H and as I have no short there anymore it shouldn't be the reason. My ISL ( U7000) was just freshly replaced and shouldn't be the cause. As the SMC is the only thing left on that circuit. . . Do I assume right it is bad and has to be the cause ? |
11-06-2016, 16:19 | #4 (permalink) |
Member: 2642557 Status: Offline Thanks Meter: 1 | ok, did you had liquid damage with the board? By injecting 3,4 V to PP3V42_G3H rail i guess you burned away the short [capacitor or something similar] Now do you get any voltage at the output of U6690 by connecting magsafe power? I guess you mean R5087, measure it to check its resistance. You can try to remove U7000, clean the pads and do some measurments without it. |
12-01-2016, 16:10 | #5 (permalink) |
Member: 1695219 Status: Offline Thanks Meter: 16 | aha yes,*I am a little busy now and also i wait my donor board. Once I get back to it I will check and measure more and will remove the isl again just to go sure and sort it out . . . as like the resistor too so that before I approach to u7000 ( what is a pain with my experience level) I am sure that nothing else on that rail can be the short. And yes for sure ! This is a hell of water damage !! A corroded peace of **** which,*with the right experience level,*you wouldn't waste your time on. But I have to experiment hahah When you say "burned the short away" means that I finally destroyed the component that was the cause ? I appreciate your help and fast answer man !! Will get back to it soon bye |
12-15-2016, 19:51 | #6 (permalink) |
Member: 1695219 Status: Offline Thanks Meter: 16 | even though my donor board didn't arrive yet I was too curious and removed my ISL again. short to GND on SMC_BC_ACOK remained. I removed the SMC and the short is gone. Th chip looks perfect on both sides and the board BGA looks fine too. I assume it would be a waste of time to attempt recalling this one,*so IŽll wait for my donor board and reball the SMC of it |
