Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 11-28-2013, 22:57   #1 (permalink)
Member: 1217176
Exclamation macbook pro with folder and question mark
hi to all i have an macbook pro 15" model A1286 i locked it with iCloud (pin code ) and i forget the passcode and while trying any solution i open it and remove the hard drive and connected it to another mac and erase it with disk utility and now when i put it back when i start the mac i get a folder with question blinking i tried to shut it down and enter to startup manager (with alt key) he won't enter and i tried cmd+s nothing else the folder with question mark if some one have any solution please help me
Old 12-01-2013, 00:30   #2 (permalink)
Member: 8379
Thanks Meter: 34
You need to hold command + R during start up to enter efi menu, you then use disk utility to format and install new osx
The Following User Says Thank You to datacablelondon For This Useful Post:
Old 12-01-2013, 08:37   #3 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 129
You can start reading this post .
You have to remove the EFI password & after that install new OS X
baboom
The Following User Says Thank You to baboom For This Useful Post:
Old 12-01-2013, 16:57   #4 (permalink)
Member: 2042442
Thanks Meter: 13
I must suggest you to install new OS X... It will work then for sure
The Following User Says Thank You to Sokin4 For This Useful Post:
Old 12-01-2013, 22:35   #5 (permalink)
Member: 1217176
@datacablelondon
i tried nothing happen same problem won't enter
Old 12-01-2013, 22:39   #6 (permalink)
Member: 1217176
the problem is my mac won't enter to startup manager so i can't install anything
Old 12-01-2013, 23:55   #7 (permalink)
Member: 8379
Thanks Meter: 34
Try hold comand + R both button together before power up, if failed try option + r
Old 12-02-2013, 01:48   #8 (permalink)
Member: 1217176
i tried so many times but nothing happen
Old 12-02-2013, 13:39   #9 (permalink)
Member: 8379
Thanks Meter: 34
For late mac book
Just hold "option" key
Old 12-03-2013, 21:49   #10 (permalink)
Member: 1217176
For late mac book
tried so many times and nothing happen
Old 12-03-2013, 23:40   #11 (permalink)
Member: 8379
Thanks Meter: 34
May be your key board is faulty, try with a USB keyboard
Old 12-08-2013, 17:17   #12 (permalink)
Member: 2080861
Macbook pro retina 13` early 2013 pin code
I bought a macbook off ebay and when I connected the internet is blocked.
I need a pin code. what can i do?
Man I no longer respond to email and phone: (
can some one help me ??
Old 12-09-2013, 00:43   #13 (permalink)
Member: 8379
Thanks Meter: 34
If your mac book is before 2010, it is FREE & easy job. After 2010 mac use the 4 digit pin which will cost to unlock.
Old 12-14-2013, 19:14   #14 (permalink)
Member: 1892600
Thanks Meter: 5
u only reset boise ... regards
The Following User Says Thank You to unlockis For This Useful Post:
Old 12-18-2013, 02:08   #15 (permalink)
Member: 1217176
me too i'm searching a solution for this
Page generated in 0.37481 seconds with 7 queries
