01-17-2016, 01:07 | #2 (permalink) |
Moderator Join Date: Sep 2002 Location: Serbia/Hungary Age: 42
Member: 15994 Status: Offline Thanks Meter: 263 | do a nvram reset: 1. Shut down your Mac. 2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R. 3.Turn on your Mac. 4. Press and hold the Command-Option-P-R keys immediately after you hear the startup sound. 5.Hold these keys until the computer restarts and you hear the startup sound for a second time. 6.Release the keys. |
The Following User Says Thank You to sebagsm For This Useful Post: |
01-26-2016, 22:58 | #7 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | If you can't handle the professional way or at least deep google search> We can always contact my Grandma to double check the numbers for your Mac and the lottery. The last one worked for me )) Btw because of moonlight this weekend you can get up to 50% discount! Kimov Regards |
01-29-2016, 23:27 | #8 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2523680 Status: Offline Thanks Meter: 2 | 1. Reboot 2. Hold apple key + s key down after you hear the chime. (command + s keys on newer Macs) 3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line): mount -uw / rm /var/db/.AppleSetupDone shutdown -h now 4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again! |
02-19-2016, 18:20 | #10 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Kenya,Mombasa
Member: 40758 Status: Offline Thanks Meter: 26 | Hi Buddys i have a MacBook Pro 2009 its asking for a pin lock have tryd to reset it with all the tricks here with no luck i have dumped the file its 4mb the chips on it is MX chip 25L3205DM2I any idea to reset will be appreciated BR |
06-15-2016, 20:16 | #13 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Egypt Age: 31
Member: 2219780 Status: Offline Sonork: 100.1662738 Thanks Meter: 52 | you have two ram in your lap top remove one of them and boot your device create new password from firmware password utility put your ram again boot with the new password you can remove it sorry for my bad english |
