12-09-2013, 22:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 205933 Status: Offline Thanks Meter: 2 | Water Damage |
12-28-2013, 09:41 | #3 (permalink) |
Freak Poster Join Date: Aug 2006 Location: kanpur
Member: 330372 Status: Offline Thanks Meter: 26 | i also have same issue with macbook airA1369 fan gets starts for 2 seconds and than gets off some time it does start and work fine but this happens once in hundreds i tried to reflow and cleaned with ipa same condition and body have schematrics from which i can know which is power ic and related power section |
09-11-2014, 04:57 | #5 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1882599 Status: Offline Thanks Meter: 2 | Drying it out will not solve anything, at least not permanently. Take it apart and clean it with denatured alcohol. Take the board and put it inside a bowl full of denatured alcohol and seal it. Leave it there for 30 minutes, take it out, let it dry and install it again. |
11-06-2018, 08:06 | #8 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | Take out the battery and hard drive. Most likely the data will still be good. The battery, you'll have to examine. If it won't power on, most likely you'll need to replace the logic board. |
02-28-2019, 12:17 | #10 (permalink) |
Junior Member Join Date: Feb 2019 Location: Neverland
Member: 2896164 Status: Offline Thanks Meter: 2 | On the outside look you will not understand. It is necessary to check the circuit, check whether the battery is working correctly, dry all the boards and wipe with alcohol. The main thing is to protect the motherboard from moisture and dry it well. |
