Go Back   GSM-Forum > Premium Market place > Premium Sales section
Old 05-23-2015, 13:27   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
Z3X-BOX Samsung Pro. S6/S6 Edge - safe direct unlock, cert read/write
Z3X Samsung Tool Pro 21.1 Update. First in the world.
Added Galaxy S6, S6 EDGE Direct unlock/CERT reading - world first.
Second update of Z3X Samsung PRO. BooM Update.
New unique solution released for unlock and cert reading from S6 and S6 edge.
Unlock way is fully safe, without wipe and touch imei and any calibration data.
While unlock nv_data.bin saving in backup folder.
Added:
- support SM-T331 (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T331C (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T335 (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T337A (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T337T (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T337V (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T525(Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-T113NU (Direct Unlock,CERT Read/Write,Flashing)
- support SGH-T159 (Direct Unlock/Read codes/, Repair IMEI/SN/BT, flashing) - First in the World
- support GT-S5610K (Direct Unlock/Read codes/, Repair IMEI/SN/BT, flashing)
- support SGH-S275M (Direct Unlock/Read codes/, Repair IMEI/SN/BT, flashing)- First in the World
- support SGH-S275R (Direct Unlock/Read codes/, Repair IMEI/SN/BT, flashing)- First in the World
- support SM-N915A (Direct Unlock, Flashing, Write CERT, Reset MSL, Wipe EFS)
- support SM-G920A (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920F (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920FQ (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920I (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920K (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920L (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920S (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920T1 (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G920T (CERT Read/Write,Flashing)- First in the World
- support SM-G920W8 (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925A (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925F (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925FQ (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925I (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925K (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925L (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925S (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
- support SM-G925T (CERT Read/Write,Flashing)- First in the World
- support SM-G925W8 (Direct Unlock*,CERT Read/Write,Flashing)- First in the World
Unlock for rooted S6 and S6 Edge added in beta mode, if any problem post in forum log + attach
G920T - unlock not possible but possible G920T1 you know what to do.
G925T - unlock not possible so need wait G925T1 release.
Fixed:
- Fixed GT-i9300 SN repair,
- Fixed SM-G800F/T235 Unlock, read CERT,
- Fixed S5611 Sending FDL2... error,
- Fixed missing port in S7560/M,
- Downloaded firmware now saves to firmware_dir\short_model_name\file (if firmware dir predefined).
P.S. S6 and S6 Edge operation (Unlock or Read CERT) total count limited to 10daily for each user.
P.S2. If our monitoring system will found any cards owner who will try play with our server and other things not related to correct operation UNLOCK/CERT reading for S6, access to server will be closed for this card. (Normal users should not care about this)
P.S3. Hope solution will be not copied fast ;-)
Resellers welcome:
http://forum.gsmhosting.com/vbb/f453...llers-1943715/
The Following 9 Users Say Thank You to blang For This Useful Post:
Page generated in 0.13524 seconds with 8 queries
