Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750 |
04-01-2014, 13:29 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: In the World
Member: 644224 Status: Offline Thanks Meter: 70 | How to Android Samsung S8600 WAVE3 Br, shemul |
04-10-2014, 12:24 | #4 (permalink) |
Insane Poster Join Date: Sep 2010 Location: mumbai Age: 39
Member: 1387849 Status: Offline Sonork: 100.1623264 Thanks Meter: 15 | Android port for Samsung WAVE3 (GT-S8600) Hi all. This thread only for developers! Only! No questions - when?!!!!!!! This is my attempt to porting android on S8600. I wrote custom bootloader - emmcboot, based on codeaurora LK-bootloader. Bootloader is successfully start, work and trying to load android kernel from internal microsd card. Now is unsuccessfully,after type message "Uncompressing Linux... done, booting the kernel." device rebooted or stopped. [370] Panel is power on [370] Display initialized [370] Display logo [370] Waiting for modem+++ [370] Waiting for modem: Done [370] smem ram ptable found: ver: 0 len: 6 [370] scratch: 0x8000000 [370] Starting in SD mode! [370] SD_DETECT pin : 0x0 [380] Initializing MMC host data structure and clock! [380] Error No. 2: Failure Initializing MMC Card! [400] Decoded CID fields: [400] Manufacturer ID: 27 [400] OEM ID: 0x5048 [400] Product Name: SD16G [400] Product revision: 3.0 [400] Product serial number: 7C88FF04 [400] Manufacturing date: 2 2012 [410] Serial number -[410] serial number: [410] partition misc doesn't exist [410] error in emmc_recovery_init [580] kernel @ 208000 (4132528 bytes) [580] ramdisk @ 1200000 (175204 bytes) [580] cmdline = 'console=null androidboot.hardware=qcom user_debug=31' [580] Booting Linux [580] smem ram ptable found: ver: 0 len: 6 [580] booting linux @ 0x208000, ramdisk @ 0x1200000 (175204) [590] cmdline: console=null androidboot.hardware=qcom user_debug=31 Uncompressing Linux... done, booting the kernel. source code for lk-bootloader for S8600: https://github.com/Oleg-k/LK_BOOT_S8600 To build for S8600, type: "make -j4 s8600 EMMC_BOOT=1" Also, i got memory dump, stage - after load oemsbl and before loading my bootloader. as we see, oemsbl decompress and load apps_compressed.bin into memory, starting at 0x200000. https://www.dropbox.com/s/5wf6dp5gfg...DUMP_128MB.rar And for for understanding boot process on MSM7x30, read this: http://tjworld.net/wiki/Android/HTC/...ss#BootProcess |
The Following User Says Thank You to i_4_u89 For This Useful Post: |
04-15-2014, 02:12 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | 1 bigger problem is to play without JTAG... xda-developers - View Single Post - Android port for Samsung WAVE3 (GT-S8600) appsboot.mbn is the mandatory file, what oleg_k replaced via JTAG (RIFF Box for instance). I have now found way to kill Bootchain via Multiloader + osbl.bin... Then result is this: http://forum.gsmhosting.com/vbb/f818...e-3-a-1610764/ There are several infos about QPST and eMMC app... Maybe in combination with these files from S8600: http://forum.gsmhosting.com/vbb/10009255-post3.html 1 Tut as example: [Tutorial] Revive dead Karbonn A9+/CM Flare after JB update - xda-developers For me not solved yet, to find correct files/settings for QPST eMMC app. But this would be big step forward, if someone knows how to write something with Qualcomm Emergency DL... to S8600. Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
04-26-2014, 08:59 | #6 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | https://github.com/Oleg-k/LK_BOOT_S8600 Is someone able to tell me. How oleg_k startet kernel? It seems different way as on S8500/S8530... zImage to "Phone memory"... I9001 for instance start kernel at 0x9000000... S8600 apps_compressd is loading from 0x8000000... I have tried few JTAG dumps... Code: I9001 I8150 I8350 Best Regards |
05-01-2014, 18:11 | #7 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Is somebody here, with S8600 + solder skills + JTAG + willing to try few things? Please. If you have JTAG + S8600 you could write here or contact me via PM or in XDA forum. At the moment I need someone to confirm my "tests", maybe I do something wrong... In other words. S O S Thanx in advance. Best Regards |
05-14-2014, 17:48 | #8 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | xda-developers - View Single Post - Android port for Samsung WAVE3 (GT-S8600) I am closer to write appsboot/emmcboot to S8600... without JTAG. This means NOT Android port is finished nor started... Best Regards |
06-16-2014, 04:20 | #9 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | After QPST I found another way to write oleg_k EMMCBOOT aka appsboot into S8600... This time much easier... EMMCBOOT from oleg_k is "injected" into apps_compressed.bin from XXKJC: apps_EMMCv1 For more info: Android port for Samsung WAVE3 (GT-S8600) - Post #347 - XDA Simple use Multiloader + my modified apps_compressed.bin and you can see oleg_k Low Kernel running... Nothing more, because Android Kernel is missing... At your own risk and only for study... This means you could inject ca. 340 KB own Code into apps_compressed.bin without killing integrety... Best Regards |
07-15-2014, 05:40 | #10 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Little progress... Android port for Samsung WAVE3 (GT-S8600) - Post #493 - XDA Forum Video about S8600 booting I9001 kernel... before reboot. Android port for Samsung WAVE3 (GT-S8600) - Post #506 - XDA Forum Achieved with this I9001 dump from 0 - 0x0900 0000... and mixed with Samsung_GTI9001_2GB.rar For now only with JTAG... In theory via QPST possible... but dangerous because whole EMMC partition layout is nuked by I9001 stuff...Will try to mix with 4 GB dump... maybe longer start...Best Regards |
08-07-2014, 04:16 | #11 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Little progress: Android port for Samsung WAVE3 (GT-S8600) - Post #655 - XDA Forum If someone with S8600 and JTAG have too much time... He could help me... This is also via QPST and without JTAG possible... But more dangerous, as you have no chance without JTAG to repair Boot or other stupid Firmware ""crashes""... For study... Best Regards |
08-28-2014, 03:09 | #12 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | mXT224 mXT224E mXT224S Please, I need help to identify Touch used on S8600... I found only this Pic... better then FCC Pic, but I can NOT see all necessary infos... Thanx in advance. Best Regards Last edited by adfree; 08-28-2014 at 03:15. |
