Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750 |
05-09-2013, 13:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Punjab India
Member: 687144 Status: Offline Sonork: 1614780 Thanks Meter: 228 | samsung S5333 flashing mathod 2. Select control mode as BCRM2133 3. Check Full Download (Never check Boot Change unless you know what you are doing) 4. Click on Boot Files button and navigate to the place where you unpacked your firmware files and select bootfiles. ( IF YOUR DOWNLOADED FIRMWARE DOES NOT HAVE THE BOOT FILES ITS OKAY BUT MAKE SURE YOU ARE USING A FIRMWARE FROM YOUR REGION) 5. Click on Apps and select the file. 6. Click on Amss and select the file. If the file is not present leave this blank. 7. Click on Rsrc1 and select the file. 8. Click on Rsrc2 and select the file. ALWAYS LOW 9. Click on Factory FS and select the file. If the file is not present leave this blank. 10. Click on CSC and select the file. 11. Click on SHPAPP and select the file. 12. Click on FOTA and select the file. If the file is not present leave this blank. 13. Click on TUNE, ETC, PFS and select the file. If the files are not present leave this blank. 14. Remove SIM CARD AND MEMORY CARD from the phone. 15. In standby mode press Volume+ key + Camera button + Lock/Power button. 16. The mobile will switch into download mode. 17. Connect the mobile to PC using the data cable. Wait for a few minutes so that the drivers are installed. 18. Click on Port Search. 19. Click on Download. the flashing process takes around 8 to 10 min. |
