Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750 |
11-08-2012, 11:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Turkey
Member: 1058593 Status: Offline Sonork: 100.1625725 Thanks Meter: 433 | Samsung Wave GT-S8500 Secret Codes & Tricks Let me give you some details about secret codes (exclusively for Samsung Wave GT S8500). These codes can be easily typed on the keypad. The codes are as follows:- *2767*3855# Used for factory format. This code should be used very carefully, since it deletes all saved files and settings (including internal memory storage). It’ll re-install the phone firmware. Extreme care should be taken if using this code, as the deleted files and settings cannot be restored. *#197328640# This code can be used to enter into Service mode. You can run various tests and change settings in the service mode. *#0228# Provides detailed information about the phone’s battery type. *#7465625# The code is mainly used to get information about SIM Lock and/or Network Lock Codes to get Firmware version information *#4986*2650468# – SW Version, HW Version, MP, RF Cal Date, CSC Version, CSC Model Spec, FFS Version, RC2 Version *#1234# – SW Version and CSC Version *#1111# – FTA SW Version *#2222# – FTA HW Version WiFi & Bluetooth Test Codes *#526# - Wi-Fi Manual MFG Test Mode *#232337# – BT RF Test Mode Codes to Launch Factory Tests *#0*# – LCD test *#0673# OR *#0289# – Melody test *#0842# - Vibration test *#2663# OR *#2664# – TM Command B&R kürt memet |
