Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 03-22-2018, 15:14   #16 (permalink)
Member: 2787092
Thanks Meter: 29
How to update by dongle to v9.6 rsim12..you have software v9.6 Kinglock .
Old 03-22-2018, 15:40   #17 (permalink)
Member: 2765770
Thanks Meter: 6
First off - thank you team for the new codes!
Will you release software for dongle uodate to V9.6?
Thank you
PS. Dongle updater working on windows 10.
1. Insert dongle updater and let windows find the driver.
2. Go to device manager and check which port the dongle inserted on.
3. Leave dongle in PC and restart PC.
4. Dongle LED should now be red.
5. Open application and set com port to the one in step 2. Set baud rate to 19200. Open comm port.
6. Enter activation code.
7. Select download.
8. ****Once you have programmed one, leave the dongle in the USB port and do not close the APP. Just replace the RSIM 12 and select download. The LED will stay RED and you can program RSIM's quickly and easily. No loss from server******
I hope it helps
Cheers
Jacques
Old 03-22-2018, 16:02   #18 (permalink)
Member: 2821262
iphone 6s Sprint unlocked using mode 3G/4G supreme sharp mode, I don't know if is the best one but it worked
Thank you!!
Old 03-22-2018, 16:36   #19 (permalink)
Member: 2804692
Rsim V9.6 software?
How to update by dongle to v9.6 rsim12, where is the update sofware?
Old 03-22-2018, 17:06   #20 (permalink)
Member: 1488173
Thanks Meter: 184
Thanks, unlock done on iphone 5s sprint usa using rsim 12 v9.1 .
Keep it up team !!
Old 03-22-2018, 17:19   #21 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,061
same instructions as before
Old 03-22-2018, 17:19   #22 (permalink)
Member: 1907775
Thanks Meter: 2,061
Originally Posted by miliky View Post
Perfect automatic 4G unlock--V9.6 RSIM12
How setting V9.1 v9.2 V9.3 V.4 V9.5 RSIM12 to new Auto 4G
Some new customer don't how to install , so making this video for help.
https://www.youtube.com/watch?v=6dqXXFjxLlE
*5005*7672*00# and reelect operator.
NEW ICCID CODE:
89014103279529155468
89014103279529155393
89014103279529155401
89014103279529155690
89014103279529155708
89014103279529155427
89014103279529155435
89014103279529155443
89014103279529155450
89014103279529155484
89014103279529155492
89014103279529155500
89014103279529155526
89014103279529155534
89014103279529155542
89014103279529155559
89014103279529155591
89014103279529155625
89014103279529155633
89014103279529155641
89014103279529155658
89014103279529155666
89014103279529155674
89014103279529155682
89014103279529155724
89014103279529155732
89014103279529155567
89014103279529155575
89014103279529155583
89014103279529155740
89014103279529155765
89014103279529155773
89014103279529155476
Thanks for RSIM engineers team's hard work,
Perfect automatic 4G unlock--V9.6 RSIM12 Plug and play
The version V9.1 9.2 9.3 9.4 9.5 can be upgraded by dongle,
https://gsmserver.com/item/boxes-and-dongles/r-sim-12-unlocking-card-for-iphone-x-8-8plus-7-7plus-6s-6splus-6-6plus-5-se-5s-5c-5/
https://gsmserver.com/item/boxes-and...update-dongle/
http://forum.gsmhosting.com/vbb/f819...ongle-2309321/
The Following 2 Users Say Thank You to kinglock For This Useful Post:
Old 03-22-2018, 19:25   #23 (permalink)
Member: 2452602
If someone can help me i configure the r sim in a iphone 6s sprint and work perfect. I put the same in a iphone 7 claro company and just say invalid sim. Sim failure. How i can fix that. Iphone 7 is in 11.2.6
Old 03-22-2018, 21:56   #24 (permalink)
Member: 1695601
Sonork: tuma jay
Thanks Meter: 63
how do i update the rsim using dongle please? it is asking for active code
Old 03-22-2018, 23:37   #25 (permalink)
Member: 2787092
Thanks Meter: 29
I’m serves connect success but not start download..any suggestions to fix it.
Old 03-23-2018, 00:33   #26 (permalink)
Member: 1484663
Thanks Meter: 252
Originally Posted by Yusslayer View Post
Im serves connect success but not start download..any suggestions to fix it.
Check that the R-Sim it's properly inserted, check instructions carefully and try again. I just update one first try. BR
Old 03-23-2018, 01:02   #27 (permalink)
ernie78's Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,704
Originally Posted by rishthav View Post
89014103279529155468 not working
working tested me 100%
first
tested
The Following User Says Thank You to ernie78 For This Useful Post:
Old 03-23-2018, 06:36   #28 (permalink)
Member: 2788920
Thanks Meter: 4
89014103279529155468 not working us xenon network
Old 03-23-2018, 07:21   #29 (permalink)
Member: 2537939
Sonork: 100.1670350
Thanks Meter: 672
we like your hard working guys
Old 03-23-2018, 08:01   #30 (permalink)
Member: 2791752
what i am doing wrong?
I have Rsim 12 9.3
i have followed these steps:
(1) Dial guide code: *5005*7672*0#, select the last option in the Operator list. Edit ICCID input: 8901 4103 2795 2915 5468, and send.
(2). Dial guide code: *5005*7672*0#, select ICCID unlock in the Operator options, accept. My phone is locked to sprint so i select US Sprint and then GSM (2/3/4G card)
(3) I then shutdown my phone, remove the rsim and sim card, put the sim card alone, turn on the phone and then try to activate, after error of invalid sim card i then put the rsim and the sim card together and i try to activate again.
(4) This is where it is supposed to work but instead it either shows INVALID SIM or take me through the itune loop. In cases where the activation has gone all the way to WELCOME TO YOUR IPHONE the network says no service...
Page generated in 0.35809 seconds with 7 queries
