Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 04-26-2018, 07:22   #136 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,088
R-SIM12,GPP,GEVEY,HEICARD,HEISIM,RSIM 10,RSIM11+,RSIM 9 PRO mini air Unlock,iPhoneX,iPhone8,Firmware,Any version, No jailbreak
The Following User Says Thank You to kinglock For This Useful Post:
Old 04-26-2018, 07:23   #137 (permalink)
Member: 2793567
Thanks Meter: 6
thank you kinglock will update soon
Sent from my iPhone using Tapatalk
Old 04-26-2018, 08:28   #138 (permalink)
Member: 2800622
Originally Posted by PARMATMA View Post
I ALSO have the same issue
open File failure!
Connect Server Sucess!
Com has opened already!
always same error
change pc, comport and all
any solution ?
kalpesh varia
Try with Windows 7 OS.
Old 04-26-2018, 18:07   #139 (permalink)
Member: 2555808
Thanks Meter: 15
No Open Com!
Success to Close Com!
Do without connect in com mode.
but not starting update about 40 min
how to fix?
please download the latest rsim update app, you have an old version of the software
Old 04-26-2018, 18:20   #140 (permalink)
Member: 2555808
Thanks Meter: 15
Originally Posted by iamtj View Post
Hello give me the answer ?
no, this update its only for rsim 12
Old 04-27-2018, 01:24   #141 (permalink)
Member: 2765071
im using windows 7, nothing downloads
my rsim 12 are v9.4.....
Old 04-27-2018, 01:35   #142 (permalink)
Member: 2765071
Originally Posted by rochater View Post
program say:
but not download file!
exact same problem! did you find solution yet?
Old 04-27-2018, 04:59   #143 (permalink)
Member: 2832550
Para el que sepa espaņol...
Pude actualizar el rsim yo tenia el mismo problema que se quedaba en server connected, lo hice de esta manera yo usaba windows 10 cambie a windows 7 instale los drivers del dongle para windows 7 64bits desde la pagina de rsim descargue la ultima version del actualizador de rsim, luego que hice todo eso cambie el numero de COM en administador de dispositivos al numero 2 luego de eso la aplicacion de actualizar la puse en modo compatibilidad windows xp service pack 3, reinicie la computadora con el dongle desconectado luego conecte el dongle con el switch que trae el dongle en direccion hacia atras de el usb y asi me funciono.
Old 04-27-2018, 05:09   #144 (permalink)
Member: 2832550
For connect server succed but not download i did this.
I could update the rsim I had the same problem that stayed in server connected, I did it this way I used windows 10 change to windows 7 install the dongle drivers for windows 7 64bits from the rsim page download the latest version of the updater rsim, then I did all that change the COM number in device manager to number 2 after that the update application I put it in compatibility mode windows xp service pack 3, restart the computer with the dongle disconnected then connect the dongle with the switch that brings the dongle in the back direction of the usb and that's how it worked.
Old 04-27-2018, 11:27   #145 (permalink)
Member: 1907775
Thanks Meter: 2,088
Effective iccid code
89014103279529155419
How to unlock by rsim12 v9.6.2 after 26th April
https://www.youtube.com/watch?v=d5P9...ture=*********
Old 04-27-2018, 15:18   #146 (permalink)
Member: 2832550
For connect server success issue but not download i did this.
Old 04-27-2018, 15:19   #147 (permalink)
Member: 2555808
Thanks Meter: 15
Probastes si actualizaba otros chips o estabas enfeascado con el mismo??
Old 04-27-2018, 15:19   #148 (permalink)
Member: 2555808
Thanks Meter: 15
Try to update another chip
Old 04-27-2018, 15:29   #149 (permalink)
Member: 2832550
open File failure!
always same error
any solution ?
kalpesh varia
Old 04-27-2018, 15:41   #150 (permalink)
Member: 2832550
solo tengo 1 solo rsim12
Page generated in 0.38913 seconds with 8 queries
