04-27-2018, 03:59 | #143 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2832550 Status: Offline Thanks Meter: 0 | Para el que sepa espaņol... Pude actualizar el rsim yo tenia el mismo problema que se quedaba en server connected, lo hice de esta manera yo usaba windows 10 cambie a windows 7 instale los drivers del dongle para windows 7 64bits desde la pagina de rsim descargue la ultima version del actualizador de rsim, luego que hice todo eso cambie el numero de COM en administador de dispositivos al numero 2 luego de eso la aplicacion de actualizar la puse en modo compatibilidad windows xp service pack 3, reinicie la computadora con el dongle desconectado luego conecte el dongle con el switch que trae el dongle en direccion hacia atras de el usb y asi me funciono. |
04-27-2018, 04:09 | #144 (permalink) |
Member: 2832550 Status: Offline Thanks Meter: 0 | For connect server succed but not download i did this. I could update the rsim I had the same problem that stayed in server connected, I did it this way I used windows 10 change to windows 7 install the dongle drivers for windows 7 64bits from the rsim page download the latest version of the updater rsim, then I did all that change the COM number in device manager to number 2 after that the update application I put it in compatibility mode windows xp service pack 3, restart the computer with the dongle disconnected then connect the dongle with the switch that brings the dongle in the back direction of the usb and that's how it worked. |
04-27-2018, 10:27 | #145 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | Effective iccid code 89014103279529155419 How to unlock by rsim12 v9.6.2 after 26th April https://www.youtube.com/watch?v=d5P9...ture=********* |
04-27-2018, 14:18 | #146 (permalink) |
Member: 2832550 Status: Offline Thanks Meter: 0 | For connect server success issue but not download i did this. I could update the rsim I had the same problem that stayed in server connected, I did it this way I used windows 10 change to windows 7 install the dongle drivers for windows 7 64bits from the rsim page download the latest version of the updater rsim, then I did all that change the COM number in device manager to number 2 after that the update application I put it in compatibility mode windows xp service pack 3, restart the computer with the dongle disconnected then connect the dongle with the switch that brings the dongle in the back direction of the usb and that's how it worked. |
04-27-2018, 14:19 | #147 (permalink) | |
Insane Poster Join Date: Apr 2016 Location: La Habana
Member: 2555808 Status: Offline Thanks Meter: 17 | Quote:
Probastes si actualizaba otros chips o estabas enfeascado con el mismo?? Sent from my iPhone using Tapatalk | |
04-27-2018, 14:19 | #148 (permalink) | |
Try to update another chip Sent from my iPhone using Tapatalk | |
04-27-2018, 14:29 | #149 (permalink) | |
Member: 2832550 Status: Offline Thanks Meter: 0 | Quote:
I could update the rsim I had the same problem that stayed in server connected, I did it this way I used windows 10 change to windows 7 install the dongle drivers for windows 7 64bits from the rsim page download the latest version of the updater rsim, then I did all that change the COM number in device manager to number 2 after that the update application I put it in compatibility mode windows xp service pack 3, restart the computer with the dongle disconnected then connect the dongle with the switch that brings the dongle in the back direction of the usb and that's how it worked. | |
