07-06-2014, 15:28 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | 3g patch will not work anymore on iphone 4s ios 7.1 and up is it true |
07-06-2014, 17:51 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | I use iRose on 7.1.1 & 7.1.2. It works fine for 3G with 128K SIM. Are you jailbreaking or not? Make sure you choose Mode2 after jailbreak, Mode3 without jailbreak. |
07-06-2014, 19:36 | #3 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Good to know that 3g is still active with the patch, although the one I have was jailbroken and the 3g patch was installed and the 3g in iroostool was applied but still no go , it could be a sim card issue. |
07-07-2014, 08:47 | #4 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1172961 Status: Offline Sonork: 333 Thanks Meter: 4 | FYI, i4s verizon no need jailbrake,patch or anything. just pulg and play,everthing working. ussd not working,cause this required edit system file. with jailbrake its easy fix. |
07-07-2014, 21:44 | #5 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | HAHAHA After trying the tree modes I just figured out that the only mode that you could get the 3g was the mode 2 while before on ios 7.0.6 and prior it used to be mode 3 and mode 2 but now it works only on mode 2. |
07-07-2014, 23:39 | #6 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | Mode3 should have only got 2G with 128K SIM. I forgot that it acts just like the RSIM 9/Mini in Mode3. Mode2 with jailbreak is the best way to go for 3G. |
07-08-2014, 00:18 | #7 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Mode 3 was working good with 3g on ios 7.0.6 and prior though but not anymore for ios 7.1 and up, although luckily we still have mode 2 that works good like a champ on ios 7.1 and up ...lol. |
