11-03-2014, 06:57 | #17 (permalink) |
Junior Member Join Date: Jan 2008
Member: 681635 Status: Offline Thanks Meter: 4 | I'm working on iPhone 5c Sprint JB with R-SIM 9+ I have 3G signal too but there is a activation loop when phone is restarted. but with the first step it will won't appear again. |
11-03-2014, 08:34 | #19 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2284543 Status: Offline Thanks Meter: 6 | after i renamed the bundle my carrier now is dtac is it normal ? because i can see you're in true move but your carrier still sprint . for me changed to be dtac !! and could you tell from where did you buy r-sim and how does it cost ? |
11-03-2014, 09:24 | #20 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangkok Thailand
Member: 830167 Status: Offline Thanks Meter: 82 | OK, This is US Sprint 5S iOS 8.1 jailbroken and replace carrier bundle with CarrierLab.bundle. R-SIM 9 Pro v.8.2________ราคา 400 บาท R-SIM mini 3G V10.1_____ราคา 650 บาท iPooh_BKK |
11-07-2014, 00:57 | #26 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | RSIM 10 won't fix your issue. If you get Edge, it means you did everything right. There is a way to get 3G by using RSIM Mini 2/Air 2 and deleting setup.app and selecting iPhone 5S/5C from the menu, but for many SIM carriers don't support 3G incoming calls/SMS if you do this. Otherwise for iPhone 5 Sprint, you will need to use an old 64K SIM(new from the store for old style phones) and cut it to nano size. Otherwise, you can do factory unlock, which works for most iPhone 5 Sprint, TMobile, and ATT. Less success for 5S/5C. |
11-11-2014, 21:04 | #27 (permalink) |
Junior Member Join Date: Dec 2009 Location: haiti Age: 35
Member: 1186156 Status: Offline Thanks Meter: 0 | Thx I tested it and it works, u got 3G, is there a fix for incoming calls, I'm keep losing call, I got signal bars, I got 3G if someone try to get me, phone don't ring, he go straight to my voice mail box |
11-11-2014, 23:20 | #28 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | If you go to settings/cellular/Enable 3G/LTE-->OFF, does signal switch to Edge? If that's the case, you can download the battery saver app to switch to Edge in standby or on WiFi. When phone is in use and WiFi isn't connected, it switches to 3G. You can execute a ping command in mobileterminal to keep the connection alive. These two apps require the jailbreak from en.pangu.io I'm not sure if there are similar apps in the App Store. |
11-12-2014, 06:28 | #29 (permalink) |
Member: 1186156 Status: Offline Thanks Meter: 0 | Thx for your reply, I get edge only if I put it on 2G,i got 3 options, 2G,3G,LTE...can u tell men more about Dat ping command, I already jailbreak using pangs, thx |
11-14-2014, 17:26 | #30 (permalink) |
Member: 2284543 Status: Offline Thanks Meter: 6 | Alizakhil JB your Phone with Pangu8_v1.1.0 then download Filza from Cidya .. and you will know how to rename it .. it's easy i only try iphone 5C and 5S (Sprint) i have no idea about i phone 6 |
