Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 06-07-2018, 18:05   #1 (permalink)
Member: 2843068
iPhone 7 Sprint Rsim 12 Setup
I just purchased and received the latest rsim 12, wasn't for sure how to go about setting it up.. Im using a sprint iphone with a at&t sim card..I did the emergency dialer code, an entered iccid, but im seeing now that its blocked.
When a new iccid, becomes available. Is that all I need to do? enter *5005* dialer code, and select edit iccid and enter the new code/reset phone?
Or are the other steps I need to do for sprint? thanks
Old 06-07-2018, 18:37   #2 (permalink)
Member: 2841500
Thanks Meter: 2
My guess is that it usually takes at least 10 days or 3 weeks at the most for a new ICCID to become available. You can try the TSMI Unlock mode by entering said dial code, select US Sprint, select TSMI Unlock Mode, and then select Auto Unlock 2. I cannot guarantee that it will work, though.
Old 06-07-2018, 18:47   #3 (permalink)
Member: 2791654
Thanks Meter: 2
Hello I have a Sprint iPhone 7 plus with T-Mobile SIM and that's all I had to do . Is ur rsim 12 the black one because I had some problems with getting fake rsims . And sometimes resetting the phone power it down then back on. And see if that works. Also check the vids for rsim on You Tube , probably get more help there as well
And keep checking back for new Iccid
Sent from my iPhone using Tapatalk
Old 06-07-2018, 19:20   #4 (permalink)
Member: 2841500
Thanks Meter: 2
Is there any difference between the black RSIM and the gold RSIM? I use the black RSIM 12 and it works good for me.
The Following User Says Thank You to DragonfireEX402 For This Useful Post:
Old 06-08-2018, 19:09   #5 (permalink)
Member: 2791654
Thanks Meter: 2
I’m not sure I think the black R-Sim 12 has the new firmware already on it , it’s the only one that worked on my Sprint iPhone 7 Plus.
Old 06-09-2018, 00:12   #6 (permalink)
Member: 1484663
Thanks Meter: 344
Both works OK with Sprint and are upgradable. BR
The Following User Says Thank You to Bscaine For This Useful Post:
Page generated in 0.14725 seconds with 8 queries
