06-09-2014, 12:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Peshawar, Pakistan
Member: 1769023 Status: Offline Thanks Meter: 4,550 | Can this be used to bypass activation screen in Sprint iphone 5s Code: This method is working for me. ios 7. 0. 4, iphone 5, sprint, x-sim 1. Do jailbreak 2. After jailbreak go to cydia and update it, you will get an message inside 3. Download iFile in Cydia (google will answer you how to and where find it for free 4. Open iFile and go to :System -> Library -> Carrier Bundles -> Iphone 5. Here is a very loooong list of carriers, you need to delete this four packages: 310120, 310120_GID2-00, Sprint_LTE_US. bundle, Sprint_Virgin_US. bunde all in the second part of the list. 6. Turn off the Iphone 7. Insert your sim without x-sim 8. Turn on Iphone, wait until you'll see Activation required notice 9. Discard your sim and now reinsert it back with x-sim, if you insert rsim for the very first time you ll see x-sim activation menu, if not wait aprrox 10 secs and signal will be ok 10. Go to Settings\Cellular\ and turn on Data Roaming 11. Then from mobile browser go to website unlockit. co. nz (through Wi-Fi) and select your carrier to get APN Profile and install it. 12. Restart the phone and 3g and sms will be ok. But USSD still not working My question is that if we use the above procedure instead of 5 in 5s, can it work with RSIM and can activation required be gone after getting signals? |
06-09-2014, 15:27 | #2 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2117665 Status: Offline Thanks Meter: 39 | Some of the member on this forum got succeed to get it work for them on Sprint 5S, by using this method but they were facing signal stability problem. There phone goes into Activation, where the signal are weak. Note: Before jailbreak your phone, 1st try to unlock your phone with R Sim Air2, and if you get success getting signal (Calling function works), then you will try to do with above method. |
06-09-2014, 15:27 | #3 (permalink) |
06-09-2014, 15:28 | #4 (permalink) |
