11-04-2013, 23:22 | #1 (permalink) | |
Junior Member Join Date: Nov 2013
Member: 2059385 Status: Offline Thanks Meter: 0 | Can't activate iPhone 5S Sprint with RSIM9, Please help! Quote:
11-05-2013, 00:49 | #2 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1431235 Status: Offline Thanks Meter: 0 | you are intruducing a wrong imsi code, try 3101200 or 3160101 or 3160100. to get out of that mode use the original sim card so you can bypass activation and then switch simcard of rsim9 so you can introduce imsi code again |
11-05-2013, 08:38 | #3 (permalink) |
Member: 2059385 Status: Offline Thanks Meter: 0 | Not working either of these codes. After restarting the phone it pops up "Activation required". And when slide to activate it says that it can not connect to activation server. Usually if the code is wrong here it says that the sim is invalid. |
01-30-2014, 15:31 | #7 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Azerbaijan
Member: 622715 Status: Offline Thanks Meter: 82 | same problem iphone 5s iphone is not activated with orijinal sim card. R-sim 9 pro.Your iPhone could not be activated because the activation server is temporarily unavailable. Try connecting your iPhone to iTunes to activate it, or try again in a couple of minutes. |
10-07-2014, 03:21 | #12 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2269511 Status: Offline Thanks Meter: 1 | my iphone 5 sprint 7.0.4 give me the same message not able to activate due to not able to connect to server. i got r-sim 9 pro too. stuck at activation requires...............OMG...any help with iphone 5 ???????? |
10-07-2014, 03:21 | #13 (permalink) |
10-07-2014, 04:06 | #14 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangkok Thailand
Member: 830167 Status: Offline Thanks Meter: 82 | My's client Sprint iPhone 5 was success when I freshly restore to ios 8.0.2 via itune. And activation process through R-SIM 9 Pro + 32k sim card & cut to nano sim. |
