Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 01-21-2014, 20:25   #1 (permalink)
Member: 1943596
Thanks Meter: 15
Contacts Fix
Someone could adjust the phonebook contacts without having to use the +internacional code+ city code + number (ex +5531xxxx-xxxx)? Thnks
Old 01-21-2014, 21:59   #2 (permalink)
Member: 2072782
Thanks Meter: 12
what do you mean?
Can you be a little more specific. What exactly do you need to do? The r-sim cards rely on making the phone "believe" that the sim card you are using is from the carrier that the phone is locked to. That means , when you are using a phone from e.g. UK and you are staying in Brazil, the phone expects to get phone calls from the +44 country code. Thats you it is better to add prefix for e.g Brazil to all of your contacts in order not to have problems with call recognition and calling to numbers from contact list.
Old 01-22-2014, 14:20   #3 (permalink)
Member: 1943596
Thanks Meter: 15
I want a alternative solution to the old method using the archive "uimobilecountrycodes. plist" to edit the default country of the phone, on my case change brazil to 001 and change "us" to "br", with this i don't need to use +55 31 in the contacts number and fix the received sms, cause now they came with this country code.
Old 01-22-2014, 17:20   #4 (permalink)
Member: 1943596
Thanks Meter: 15
Exclamation This is it! The Solution!
This is it!
To solve the issue of use the internacional code +55 on brazilian carriers you need paste the archive it follow bellow on the folder:
System-Private-Frameworks-Appsupportframework- substituing the older.
The archive bellow is edited by me to use on US iphones locked, working on brazilian carriers, without need to use internacional code.
Any questions send me a message!
Archive: goo gl-NKaW4x , change - to slash
Old 01-22-2014, 19:05   #5 (permalink)
Member: 1943596
Thanks Meter: 15
Talking
Ps. Tested and working on Iphone 5 Sprint!
To another country carriers, consult me!
Old 01-22-2014, 20:58   #6 (permalink)
Member: 2032023
Thanks Meter: 3
What to change? I want to add the code of israel +972, my phone locked to us sprint, where paste the code in the folder?
Old 01-23-2014, 02:50   #7 (permalink)
Member: 31942
Thanks Meter: 42
whats the proper link of the archive?
Old 01-23-2014, 14:15   #8 (permalink)
Member: 1943596
Thanks Meter: 15
Sorry dennis, only now i can post links, follow bellow the correct adress:
http :// goo . gl / NKaW4x
without spaces!
download this, and paste into the folder.
Ps. brazilian carriers only!
Old 01-23-2014, 14:19   #9 (permalink)
Member: 1943596
Thanks Meter: 15
salalha i'll make a archive for you, wait!
Old 01-23-2014, 14:38   #10 (permalink)
Member: 1943596
Thanks Meter: 15
the link with the edited archive for Isreal's carriers:
Defaultphoneisrrael - Download - 4shared - Eduardo Castro
Old 01-23-2014, 14:41   #11 (permalink)
Member: 1943596
Thanks Meter: 15
Default - Download - 4shared - Eduardo Castro
without spaces!
The Following User Says Thank You to edurevenge For This Useful Post:
Old 01-23-2014, 15:23   #12 (permalink)
Member: 31942
Thanks Meter: 42
ok thanks bro. will check it out.
Old 01-23-2014, 15:26   #13 (permalink)
Member: 31942
Thanks Meter: 42
what program you use to open the file bro? i want to see the structure of the file inside.
Old 01-23-2014, 15:27   #14 (permalink)
Member: 2032023
Thanks Meter: 3
Dosent work ..........
Old 01-23-2014, 15:40   #15 (permalink)
Member: 2032023
Thanks Meter: 3
this is from iTools:
DeviceName: 4S iPhone
DeviceClass: iPhone
ProductType: iPhone4,1
ProductVersion: 7.0.4
SerialNumber: *
UniqueDeviceID: *
ModelNumber: *
BuildVersion: *
HardwareModel: *
DeviceColor: white
RegionInfo: LL/A
CPUArchitecture: *
WiFiAddress: *
BluetoothAddress: *
FirmwareVersion: *
ActivationState: Activated
ActivationStateAcknowledged: True
BasebandVersion: 5.0.02
BasebandChipId: *
BasebandGoldCertId: 2
ICCID: *
IMEI: *
IMSI: *
MLBSerialNumber: *
MobileSubscriberCountryCode: 316
MobileSubscriberNetworkCode: 010
PasswordProtected: True
PhoneNumber: +972 5***********
ProductionSOC: True
ProtocolVersion: 2
SIMStatus: kCTSIMSupportSIMStatusReady
SupportedDeviceFamilies: 1
TimeIntervalSince1970: 1390487602
TimeZone: Asia/Jerusalem
TimeZoneOffsetFromUTC: 7200
UniqueChipID: *
Uses24HourClock: False
iTunesHasConnected: True
Keyboard: he_IL@hw=Hebrew;sw=Hebrew
BatteryIsCharging: True
BatteryCurrentCapacity: 100
Warranty Exp: Expired
Region: US
Description: iPhone 4S
Contact: http://www.apple.com/support/contact..._contacts.html
see the regtion is US !
and MobileSubscriberCountryCode: 316
codes of USA !
this is what we have to change.. but how?!
Page generated in 0.21274 seconds with 8 queries
