09-12-2013, 15:18 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2024066 Status: Offline Thanks Meter: 0 | R-SIM 7+ activation required |
09-25-2013, 08:50 | #4 (permalink) |
Member: 2032854 Status: Offline Thanks Meter: 0 | okay after a lot of struggle with this problem i had to go out and buy a new R-sim 7+ to fix this problem. What you guys can try: 1. Get another sim card and try to piggyback it on your R-sim and see how your phone responds, if it works with another sim then enter the IMSI code for your original sim provider and follow on-screen instructions to Accept and reboot. Once your phone reboots try loading your original sim, the phone should accept your original sim and not ask for Activation anymore. Also patch your phone with the 3G patch in case you want to use 3g just to be on safer side. In case it doesn't accept, jump to 2nd solution: 2. Get a new R-sim 7 or 8 - Ask any of your friends if you know of someone using R-sim, try theirs on your phone, if not BUY A NEW R-SIM! My experience: I tried with another simcard on my R-sim, it worked, it asked me to select carrier or edit IMSI. But since my iphone's battery was low i couldn't get a chance to reboot it, it turned off itself and i was back to square one :| So i went ahead and bought a new R-Sim7+ and it worked too. PS - You get one chance per simcard with this problem so make sure you have enough battery power and time, almost feels like a super-spy's mission. Hope this helps! Thanks, Aman Last edited by azeeblazin; 09-25-2013 at 08:52. Reason: added p.s. |
