Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 04-18-2014, 11:08   #1 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,693
FAQ about R-SIM MINI 2 for iPhone5s /5c iOS7.1 SMS and Internet problem
Old 04-18-2014, 11:13   #2 (permalink)
Member: 1288185
Thanks Meter: 74
Hi..
I tried V9.3 on AT&T & TMOBILE USA locked iPhone 5S
But only one vodafone India sim is working
No other sim is working...Its going to activation..
I also tried your way to get signal..But no success...
Any solution..??
Old 04-18-2014, 11:17   #3 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
height of optimism !!
FAQ is totally ABSURD until everyone is assured of the smooth working of r-sim mini2 with any carrier locked iphone & user's choice sim.
R-Sim Mini2 - First ENSURE it is working with all the sim and all the carrier locked iphones. [in particular 5S & 5C].
There are tons of problems and yet no proper reply. Giving a You Tube link is not the real SUPPORT, Sir !!!
Network bar appears - then goes to activation screen then sudden exit then again Network signals.
Moreover - somewhere you had suggested that upgrade mini2 sim to new firmware version 9.3.
BUT when we try to upgrade it asks for a CODE - NOW how to get that code ?? Do i need to contact you OR is it an automated process ??
Quick reply would be highly appreciated.
Best Regards.
The Following User Says Thank You to i_seeque For This Useful Post:
Old 04-18-2014, 11:55   #4 (permalink)
Member: 1907775
Thanks Meter: 2,693
Best Regards.
ask your reseller for code if mini2 , can ask skype:r-simshop if mini card
Old 04-18-2014, 11:59   #5 (permalink)
Member: 1907775
Thanks Meter: 2,693
Best Regards.
https://www.youtube.com/watch?v=2Nx1_tE9nMU
https://www.youtube.com/watch?v=TUt2ZHBASiU
Old 04-18-2014, 12:13   #6 (permalink)
Member: 1288185
Thanks Meter: 74
I tried this way but...still same
Searching for signal.....going to activation screen....again to home screen & searching for signal..
Old 04-18-2014, 13:42   #7 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Well in my opinion R-sim mini2 is a copy of R-sim mini gold with a different application to become compatible with ios 7.1 and as usually a partial solution and not complete and which this whole thing could have been done through updating R-sim gold and without the need of buying a new chip called R-sim mini2. Please R-sim if possible present us a valid and complete solution and do not rush the product out before you have completed.
JMO
Old 04-18-2014, 17:35   #8 (permalink)
Crazy Poster
Member: 2130572
All. Carrier? Ussd code and 3G ?
Sent from my iPhone using Tapatalk
Old 04-18-2014, 20:40   #9 (permalink)
Member: 2160880
Thanks Meter: 17
JMO
That is exactly what I think as well. Mini2=v9.2/9.3
Old 04-18-2014, 22:30   #10 (permalink)
Member: 1767456
Sonork: 1621131
Thanks Meter: 62
Why no one make video and show incoming call ?
That's SIMPLE - Because when iphone is on stand-by = NO INCOMING CALL Working !
I tried iPhone 5S + R-sim mini2 v9.3 - using youtube video - i got Signal and can call , but not 3G internet ...
Well after some network settings reset and sim cards changing - got Working :
Call , USSD , internet 3G , but found that i can receive calls only when i make call and close outgoing call - for 2-3 minuts i'm able to receive incoming calls from other , if i put iPhone in standby - no any incoming calls .
So i think a fix should be made and should come
Old 04-18-2014, 23:14   #11 (permalink)
Member: 2160880
Thanks Meter: 17
sounds like v9.4 is coming real soon....
Old 04-24-2014, 13:32   #12 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
i updated to v9.5 and it is working smooth.
Only problem is if 3G/LTE ON then
NO incoming calls.
Working Good only if 2G is enabled OR Data is completely OFF.
Frequent Activation & Deactivation problem has not occurred yet with new firmware v9.5 so far.
So Give it a TRY.
Old 04-24-2014, 13:59   #13 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
working only with vodafone india sim on other sim it always says sim not valid
Old 04-24-2014, 14:49   #14 (permalink)
Member: 2160880
Thanks Meter: 17
NO incoming calls.
So Give it a TRY.
Did you apply another patch or just mini v9.5?
Did you follow an specific video steps can you share?
thanks,
Page generated in 0.21265 seconds with 8 queries
