Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 12-26-2013, 09:08   #61 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 236
Kddi AU working ios 7.0.4
Sms all working
bUt 3g Not work
Old 12-26-2013, 10:47   #62 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
iPhone 5 sprint CDMA done Rsim9-PRO with 3G and SMS !!!
with 3G and SMS !!!
File Type: jpg 1533790_767643076582415_864118887_n.jpg (40.7 KB, 142 views)
File Type: jpg 1511371_767643089915747_499224447_n.jpg (42.0 KB, 104 views)
The Following User Says Thank You to Ron2pet For This Useful Post:
Old 12-26-2013, 13:24   #63 (permalink)
Member: 624834
Sms all working
bUt 3g Not work
How did you get SMS working? I am using RSIM7+ and its jailbroken. i changed BhartiAirtel to KDDI in the /System/Library/Carrier Bundle folder. I need to maintain two separate threads. Do you have any solution?
Old 12-26-2013, 23:28   #64 (permalink)
Member: 2091615
Thanks Meter: 9
did you try 128k sims? or any lte sims?
Old 12-27-2013, 06:01   #65 (permalink)
Member: 2067304
Thanks Meter: 50
our reseller will try and test
Old 12-27-2013, 07:44   #66 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 236
im fix 3g bro
im used patch im buy key no jb
end now all working
try bro
Step 1: Connect to the internet via WiFi
Step 2: Go tohttp://www.unlockit.co.nz/- in Safari
Step 3: Select custom APN and choose your carrier
Step 4: Click install for the custom APN and data should now work over 3G/Edge
The Following User Says Thank You to kerug-bali For This Useful Post:
Old 12-27-2013, 21:19   #67 (permalink)
Member: 2093431
Sms working but no internet.
Please help
Old 12-28-2013, 19:27   #68 (permalink)
Member: 624834
I have had 3G working since day one on my KDDI iPhone 5 using RSim7+ but the only issue I'm facing is the SMS issue. I can send send SMS if international prefix is removed otherwise the message is not delivered. Is there a fix for this? I want to be able to to text normally and not maintain two different threads for one conversation. I'm running 7.0.4 Jail broken.
Old 12-29-2013, 05:42   #69 (permalink)
Member: 1172961
Sonork: 333
Thanks Meter: 4
Maybe you need to change your rsim to 8or9
Old 12-29-2013, 08:07   #70 (permalink)
Member: 2092085
Thanks Dude.... Your r the boss
Old 12-30-2013, 17:12   #71 (permalink)
Member: 2053595
Happened the same to me and was resolved copying (with iFile) the actual carrier bundle to the original carrier bundle of the phone.
Old 01-04-2014, 06:15   #72 (permalink)
Member: 624834
would you mind detailing the whole process? Do i need to do it after a factory reset or i can do it while the phone is up and running. and do i need to first insert the sim without the R-Sim. what is the whole process, can you please tell me?
Old 01-06-2014, 12:22   #73 (permalink)
Member: 2053595
For the carrier bundle you can use iFile (need jailbreak) and go to /system/library/carrier bundles/iphone and rename/backup the bundle of the originial carrier of your iphone - copy the name of the bundle, you'll need it later. next find the bundle of your SIM carrier and rename it to bundle of the phone carrier that you copied previously.
After that just reboot. You can check in settings>general>info that your carrier will show the carrier of the bundle renamed. NOTE: do NOT update the carrier settings in that screen.
Old 01-07-2014, 04:32   #74 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Yes but the question is where to find the carrier bundle for the desired carrier so we can swap it with the existing one, if anyone can post them here or maybe he can post a lead point or a link or a source of where they could be found than that would be a great help and much appreciated.
Old 01-07-2014, 06:07   #75 (permalink)
Member: 2003427
Sms all working
bUt 3g Not work
I m using the rsim mini+ on the japan Au kddi for ios 6.1.4
3G: from unlockit.co,nz works perfect
SMS: Not able to send the SMS
how did u fix SMS things?
Page generated in 0.28600 seconds with 10 queries
