05-31-2014, 07:13 | #122 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 870879 Status: Offline Thanks Meter: 21 | rsim mini plus confusion hi to all ..i want to ask if rsim mini plus can be activate without original sim card''? and also i try to install rsim by selecting the imsi code without the original sim card and it not activation my iphone 5c ,,the imsi code is correct but the sim is from another network ...and i dont no where to found sweden sim card and im here in spain.. |
06-17-2014, 08:03 | #124 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2206311 Status: Offline Thanks Meter: 0 | I ordered a Rsim mini plus from the rsim, it said it will work on Sprint ios7._. Not only it doesn't work on my Sprint iphone ios 7.06 Last edited by kinglock; 06-17-2014 at 08:36. |
06-20-2014, 18:20 | #126 (permalink) |
Member: 2208296 Status: Offline Thanks Meter: 0 | unlock iPhone 4s Sprint carrier Hi everyon. I have an iPhone 4S sprint iOS 7.04. And i'm very confuse!! which unlock chip i should buy? I should buy Rsim 9 PRO, or Rsim air 2? which one is more stable and works sms and 3g? My sim card must be 64k or do not need? My phone it's a 4s |
07-01-2014, 11:58 | #133 (permalink) | |
Freak Poster Join Date: Apr 2014 Location: iCloud
Member: 2160880 Status: Offline Thanks Meter: 17 | Quote:
When 3G enabled, incoming calls FAIL AND when travelling abroad the signal get lost and then the SIM INVALID message shows. Firmware is not stable yet with 3G enabled. AND sometimes is not stable with 2G. Incoming calls with 2G (Edge) works good but when traveling it crashes and loose signal. When will you update the firmware to fix these issues ? | |
07-03-2014, 00:20 | #134 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2215697 Status: Offline Thanks Meter: 0 | Hi, im new to this forum Iphone 5 Au KDDI Japan Carrier KDDI 16.1 version 7.1 (11D167) NOT JAILBROKEN :/ *sms problem* can it be solved without jailbreak? same problem, that can't send sms with international prefixes have maintain two different threads; one for receiving and other for sending please help i feel just too disturbed Last edited by Haseeb.ic; 07-03-2014 at 00:30. |
