07-18-2014, 20:46 | #226 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | |
09-05-2014, 21:09 | #228 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2252852 Status: Offline Thanks Meter: 0 | Hello guys, last night read about this solution. bought a RSIM 9 pro but at the moment didn't work with my ATT iPhone 5s...downloaded the patch last and had to work around getting the code because INSTRUCTIONS ARE NOT CLEAR....Eventho paid for the code at rpatch[dot]com and haven't got it yet, neither a response from the people on Skype they point as a contact. Now a couple of questions: 1. do I still need the rsim inside the phone after the patch or does it work without it? 2. will it bypass the sim activation screen on the iphone? 3. lastly given the situation rpatch doesn't reply, should I pull my payment back or should I wait? thanks for your help |
09-10-2014, 12:30 | #229 (permalink) | |
Junior Member Join Date: Jul 2014 Location: Warsaw / Poland
Member: 2231916 Status: Offline Thanks Meter: 2 | Quote:
No, when you remove rsim from you iphone, it cause that activation screen will come back and will be impossible to remove it in any other way (unless you put again rsim inside). If you got a rpatch activation code and it does not work, just try later, it lasts sometimes few days when it start works. If you don't recieve before ordered rpatch code, try to contact with the seller, it should reply in 3 days from order as in my case. | |
10-17-2014, 05:59 | #235 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2275629 Status: Offline Thanks Meter: 1 | Hi, I have tried to install the rpatch tool as well as ir0se, but neither will install. When I try to download and install them I get the error: "Unable to Download App "RpatchTool" could not be installed at this time." I have tried on multiple phones and get the same error on all of them. One of the phones had the ir0se tool on it previously, but it too cannot install now. I have not updated the OS. It is ios 7.1.2. Has anyone had this issue and been able to get around it? I'm afraid that apple might have found a way to block the patch install. |
10-17-2014, 07:38 | #236 (permalink) | |
Member: 2275629 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to lemmons For This Useful Post: |
10-20-2014, 23:15 | #238 (permalink) |
Member: 2276118 Status: Offline Thanks Meter: 0 | Hi , my iphone 5 (AU japan) is unable to install iR0se patch or nono4g or RPATCH. Any idea ?? I tried pp25 or iTools to install .ipa but it failed with "verification failed" message. I even tried from safari also but all in vain. Please help .. |
10-20-2014, 23:59 | #239 (permalink) |
Member: 2276118 Status: Offline Thanks Meter: 0 | iphone5 with 7.0.4 (au japan) with rsim9 , iR0se patch not installing. HI , I cannot install iR0se patch or Rpatch for phone 5 (7.0.4, Au japan). iR0se was working fine but suddenly stopped working. now Icannot even install it again. |
