Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-18-2014, 20:46   #226 (permalink)
Member: 1938435
Thanks Meter: 208
Originally Posted by lmartinho View Post
Hello all, for the LTE patch to work is it necessary to have the device jailbroken?
I have 7.1.2, no jailbreak yet, and although I activated the LTE patch, 3G still doesn't show up, only Egde...
Txs,
LM
The LTE patch is to get 2G service. LTE patch enabled=2G + service. LTE patch disabled or not installed=No Service. It's the same as iRose 2G(patch enabled) vs. 3G(patch disabled).
Old 07-31-2014, 13:29   #227 (permalink)
Member: 2217992
change carrierbundle also work
Old 09-05-2014, 21:09   #228 (permalink)
Member: 2252852
Hello guys, last night read about this solution. bought a RSIM 9 pro but at the moment didn't work with my ATT iPhone 5s...downloaded the patch last and had to work around getting the code because INSTRUCTIONS ARE NOT CLEAR....Eventho paid for the code at rpatch[dot]com and haven't got it yet, neither a response from the people on Skype they point as a contact.
Now a couple of questions:
1. do I still need the rsim inside the phone after the patch or does it work without it?
2. will it bypass the sim activation screen on the iphone?
3. lastly given the situation rpatch doesn't reply, should I pull my payment back or should I wait?
thanks for your help
Old 09-10-2014, 12:30   #229 (permalink)
Member: 2231916
Thanks Meter: 2
Hi,
No, when you remove rsim from you iphone, it cause that activation screen will come back and will be impossible to remove it in any other way (unless you put again rsim inside).
If you got a rpatch activation code and it does not work, just try later, it lasts sometimes few days when it start works. If you don't recieve before ordered rpatch code, try to contact with the seller, it should reply in 3 days from order as in my case.
Old 09-20-2014, 20:41   #230 (permalink)
Member: 2261049
Hello. I have iPhone 5 (Sprint, USA) ios 7.1.2 and R-SIM 9 PRO. send me please activation code. Thank you.
Old 09-21-2014, 08:12   #231 (permalink)
Member: 2187459
Will the RSIM Patch work on Ios 8?
Old 10-13-2014, 12:07   #232 (permalink)
Member: 72738
Hi there,
Is there any problem with the Rpatch online ?
My Ios 8.0.2 iphone says it cannot be installed on device.
Can someone help me ?
Old 10-13-2014, 12:09   #233 (permalink)
iamtj's Avatar
Member: 2048052
Thanks Meter: 18
www dot th-unlock dot com /nano4g
Sent from my iPhone using Tapatalk
Old 10-13-2014, 12:32   #234 (permalink)
Member: 72738
Thanks.
A window appears, I say "yes" to install and nothing happens....
Old 10-17-2014, 05:59   #235 (permalink)
Member: 2275629
Hi, I have tried to install the rpatch tool as well as ir0se, but neither will install. When I try to download and install them I get the error: "Unable to Download App "RpatchTool" could not be installed at this time."
I have tried on multiple phones and get the same error on all of them. One of the phones had the ir0se tool on it previously, but it too cannot install now. I have not updated the OS. It is ios 7.1.2.
Has anyone had this issue and been able to get around it? I'm afraid that apple might have found a way to block the patch install.
Old 10-17-2014, 07:38   #236 (permalink)
Member: 2275629
I was able to figure it out myself. It's really strange, but if you set your clock back to June 2, 2014 8:30 PM you can install the software.
The Following User Says Thank You to lemmons For This Useful Post:
Old 10-20-2014, 09:23   #237 (permalink)
Member: 72738
That may be true, but not for ios 8 version.
I tried the one that says ios 8 but still no 4G :|
Old 10-20-2014, 23:15   #238 (permalink)
Member: 2276118
Hi , my iphone 5 (AU japan) is unable to install iR0se patch or nono4g or RPATCH.
Any idea ?? I tried pp25 or iTools to install .ipa but it failed with "verification failed" message. I even tried from safari also but all in vain.
Please help ..
Old 10-20-2014, 23:59   #239 (permalink)
Member: 2276118
iphone5 with 7.0.4 (au japan) with rsim9 , iR0se patch not installing.
HI ,
I cannot install iR0se patch or Rpatch for phone 5 (7.0.4, Au japan).
iR0se was working fine but suddenly stopped working. now Icannot even install it again.
Old 10-21-2014, 16:55   #240 (permalink)
Member: 2278233
Any idea when the iOS 8.0.2 patch will be released? Unlock works perfectly but the data is not working
Page generated in 0.22529 seconds with 10 queries
