-   R-SIM & SAM SIM (http://forum.gsmhosting.com/vbb/f819/)
-   -   How to use R-SIM patch, For i5S/5C/5/4S LTE iOS7.1-7.X (http://forum.gsmhosting.com/vbb/f819/how-use-r-sim-patch-i5s-5c-5-4s-lte-ios7-1-7-x-1795915/)
miliky 03-28-2014 16:00
Compare new patch with old one,update as follow(The main problem that Rpatch activation card can resolve):
1 The Rpatch can not be installed directly on ios;7.1-7.x before,because it was blocked by Ios, and completely useless on iPhone 5 5s 5c.if it was blocked at broad,that means 3G/4G SIM card can not use on any iPhone,but the card of Global operators released almost are 3G or more,if no new Rpatch,that means the card abroad is useless.the new Rpatch are conquered the Ios7 completely,and it can stall and use in any iPhone(especially stand out in AU from Japan ,Softbank and Docomo)Rpatch is the only one and first one to support the Rpatch installed on line of Ios 7.1 system, help all 3G-4G SIM card abroad unlock and use.
2 the methods of installing Rpatch before is complicated,cos it needs connecting PC data cable and installing according PC system software,it caused inconvinece.(it needed date cable ,take pc with, install itunes and so on).even it can not install for connection problems. new rpatch can install one-click on line by connection iPhone with wifi.it’s very convenient to use.
3 The Rpatch did not support refreshing on line before,but new Rpatch integrate various software and information of the unlock card line ,so that you can master unlock card news and information,and Rpatch reserve access entry of ios:8 and ios:7.x,after new Rpatch refreshing,user can refresh on line directly.
The first step:Connect your iPhone with WIFI(Make sure that network speed is good), and open your iPhone desktop Safari web browser(as the following picture)
http://www.rsim5.com/upload/attached...2954_65851.jpghttp://www.rsim5.com/upload/attached...3025_77351.jpg
The second step:Please input LTE3G/4G USIM Cards patch address: www.rsim5.com/Rpatch, and please click “GO”, and then click “Install the patch immediately”
http://www.rsim5.com/upload/attached...3841_69403.jpghttp://www.rsim5.com/upload/attached...3916_13677.jpg
The third step:Please click “Install”, it will show the icon”Installing....” on the desktop.
http://www.rsim5.com/upload/attached...3952_80554.jpghttp://www.rsim5.com/upload/attached...4052_42409.jpg
The fourth step:After finishing the above steps, the desktop will show a blue and red icon about complete “Rpatch Tool”, and please click the R-SIM Logo icon again, And click the first "Install LTE Rpatch" in Rpatch Store installation interface,then select the corresponding models and iOS(for example you should choose 5c/5s Ios:7.1 if your iPhone is 5 s Ios7 s).PS:Navigation menu has function of the corresponding connection and updating patch in the Rpatch store.
http://www.rsim5.com/upload/attached...4226_80732.jpghttp://www.rsim5.com/upload/attached...4858_50564.jpg
The fifth step:it will show the picture of activation code after click Patch for LTE, please type 12 digit Activation codes in the Activation code space, then click “OK ( PS:This activation code only is usded for the Rpatch software.It is different from the old activation code that it begins with "R" or "W" and can not useed for the old activation code software.)
http://www.rsim5.com/upload/attached...5215_93268.jpghttp://www.rsim5.com/upload/attached...5315_51624.jpg
The sixth step:it will show “Success!”after type the right Rpatch code,then coick “OK”,means installation complete .(you can can arbitrarily changethe the key of Patch for LTE after installation complete,please attention : you do not need to do it again after type the right activation code. Just click the “OK”when prompted to type the activation code patches)
http://www.rsim5.com/upload/attached...5350_42755.jpghttp://www.rsim5.com/upload/attached...5420_32810.jpg
coolnitman 03-28-2014 16:08
Works on 5S Sprint ?
Sent from my iPad using Tapatalk
lus4 03-28-2014 16:20
So it works with every model of cdma iPhones and solves 3g/sms issues, right?
rafa_apm 03-28-2014 16:26
it works for 128k cards? I instal on my 5, when put "for i5/4s" it closes...
miliky 03-28-2014 16:41
can leave message to me
BRUTEFORCER 03-28-2014 16:50
i left message you in skype and in sonork already but you are offline also
ashish_beri 03-28-2014 16:53
will rsim work on IOS 7.1 on AT&T iphone 5s & 5c..??
BRUTEFORCER 03-28-2014 17:01
still no answer from support
meet124 03-28-2014 17:58
This method is working with iPhone 5s(Sprint) ?
serg670204 03-28-2014 18:52
tell me where to get the activation code patch
SIMTester 03-28-2014 18:52
How did you get RPatch activation code?
rafa_apm 03-28-2014 19:01
I dont have, before ask the code, the app shutdown when I choose 4s/5
serg670204 03-28-2014 19:13
robi4020 03-28-2014 20:01
serg670204 03-28-2014 20:09
the patch is released and where to get the code is not something says
Page generated in 0.27381 seconds with 5 queries
