06-19-2014, 20:56 | #211 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2207785 Status: Offline Thanks Meter: 1 | I bought from ebay a r-sim mini 2 to unlock it but it seems i got a broke r-sim because no popup and no sim applications section in settings > phone but i discovered something very intersting that could help some of you. I remove the r-sim and got my iphone partially unlocked thanks to irosetool by forcing 2G call in and out working sms in and out working edge ok all this without the r-sim is it normal? and who can help to further unlock and get 3G/4G working |
07-02-2014, 09:50 | #214 (permalink) |
Insane Poster Join Date: May 2014
Member: 2187459 Status: Offline Thanks Meter: 0 | 1.Will this patch work 7.1.2 for any iphone above 4 models 2. I have installed the patch my number is unknown (Settings>Phone>My No : Unknown) but when i install chat app(most of the apps), the apps tells that sim detected as Netherland but i live in INDIA will this problem can be solved? 3.Solution for My no: Unkown (Settings>Phone>My No : Unknown) |
07-08-2014, 18:13 | #217 (permalink) |
Freak Poster Join Date: Apr 2014 Location: iCloud
Member: 2160880 Status: Offline Thanks Meter: 17 | R-SIM mini2 has a BIG BIG BIG issue when 3G enabled. When 3G enabled, incoming calls FAIL AND when travelling abroad the signal get lost and then the SIM INVALID message shows. Firmware is not stable yet with 3G enabled. AND sometimes is not stable with 2G. Incoming calls with 2G (Edge) works good but when traveling it crashes and loose signal. When will you update the firmware to fix these issues ? |
07-12-2014, 07:48 | #220 (permalink) | |
Junior Member Join Date: Jul 2004 Location: Colombo, Sri Lanka Age: 49
Member: 73854 Status: Offline Thanks Meter: 1 | Quote: Hope RSIM team will give us a working fix. | |
07-16-2014, 17:03 | #223 (permalink) |
Junior Member Join Date: Jul 2008
Member: 814915 Status: Offline Thanks Meter: 0 | Question about 3G patch usability Hello all, for the LTE patch to work is it necessary to have the device jailbroken? I have 7.1.2, no jailbreak yet, and although I activated the LTE patch, 3G still doesn't show up, only Egde... Txs, LM |
07-16-2014, 21:11 | #224 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2223788 Status: Offline Thanks Meter: 0 | hi, I've bought a R-SIM Air to unlock my Iphone 4s 7.1.2 SPRINT for european carrier but I Always receive Invalid sim. I'd like to use the patch but I do not know where I can retrieve the activation code. thanks |
