Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 03-29-2014, 19:13   #46 (permalink)
Member: 2153658
Originally Posted by pabloMG View Post
on iphone 5c and 5s you CAN NOT use any sim!!!!
So u mean we still cannot use 5c 5s if its locked? only the LTE itself!?
Old 03-29-2014, 19:27   #47 (permalink)
Member: 2031664
Thanks Meter: 36
if you have a iphone 5s 5c sprint you only use it IPOD,no unlock for this phones!trust me y tried!
Old 03-29-2014, 19:41   #48 (permalink)
Member: 2122818
Thanks Meter: 19
I also have four iphones 5s sprint/virgin and I am waiting for unlock solution since november 2013.
I am fed up with these paper weight devices.
Old 03-30-2014, 00:03   #49 (permalink)
Member: 2033795
the pach dont work to iusacell mexico 5s 7.1
Originally Posted by miliky View Post
can leave message to me
is not workin tha pach to unlock 5s iusacell 7.1
Old 03-30-2014, 02:01   #50 (permalink)
Member: 2117377
Thanks Meter: 7
Originally Posted by nitto1320i View Post
buy a 64bit normal sim and cut it to fit micro sim if you need 3g internet.
stupid guy wwith stupid answer, 5c sprint can't unlock
Old 03-30-2014, 04:54   #51 (permalink)
Member: 2067304
Thanks Meter: 50
Originally Posted by coolnitman View Post
Works on 5S Sprint ?
Sent from my iPad using Tapatalk
for usim 128sim card ,japan ios7.1 iphone5s ,sb ,dc ,au
Old 03-30-2014, 06:33   #52 (permalink)
Member: 73854
Did anyone success this r-patch on iPhone 5S iOS 7.1?
And got 3G or 4G/LTE on data?
Old 03-30-2014, 07:34   #53 (permalink)
Member: 2157139
what's use ?
RSIM developers have not been able to unlock iphone 5s (ios 7.1) and now they have released this rpatch for ios 7.1.
I fail to understand that why they mention 5s/5c even knowing that these cells are locked to ios 7.1 ?
Old 03-30-2014, 08:48   #54 (permalink)
Member: 1899191
Sonork: 100.1625109
Thanks Meter: 135
Compare new patch with old one,update as follow(The main problem that Rpatch activation card can resolve):
1 The Rpatch can not be installed directly on ios;7.1-7.x before,because it was blocked by Ios, and completely useless on iPhone 5 5s 5c.if it was blocked at broad,that means 3G/4G SIM card can not use on any iPhone,but the card of Global operators released almost are 3G or more,if no new Rpatch,that means the card abroad is useless.the new Rpatch are conquered the Ios7 completely,and it can stall and use in any iPhone(especially stand out in AU from Japan ,Softbank and Docomo)Rpatch is the only one and first one to support the Rpatch installed on line of Ios 7.1 system, help all 3G-4G SIM card abroad unlock and use.
2 the methods of installing Rpatch before is complicated,cos it needs connecting PC data cable and installing according PC system software,it caused inconvinece.(it needed date cable ,take pc with, install itunes and so on).even it can not install for connection problems. new rpatch can install one-click on line by connection iPhone with wifi.it’s very convenient to use.
3 The Rpatch did not support refreshing on line before,but new Rpatch integrate various software and information of the unlock card line ,so that you can master unlock card news and information,and Rpatch reserve access entry of ios:8 and ios:7.x,after new Rpatch refreshing,user can refresh on line directly.
The first step:Connect your iPhone with WIFI(Make sure that network speed is good), and open your iPhone desktop Safari web browser(as the following picture)
The second step:Please input LTE3G/4G USIM Cards patch address: www.rsim5.com/Rpatch, and please click “GO”, and then click “Install the patch immediately”
The third step:Please click “Install”, it will show the icon”Installing....” on the desktop.
The fourth step:After finishing the above steps, the desktop will show a blue and red icon about complete “Rpatch Tool”, and please click the R-SIM Logo icon again, And click the first "Install LTE Rpatch" in Rpatch Store installation interface,then select the corresponding models and iOS(for example you should choose 5c/5s Ios:7.1 if your iPhone is 5 s Ios7 s).PS:Navigation menu has function of the corresponding connection and updating patch in the Rpatch store.
The fifth step:it will show the picture of activation code after click Patch for LTE, please type 12 digit Activation codes in the Activation code space, then click “OK ( PS:This activation code only is usded for the Rpatch software.It is different from the old activation code that it begins with "R" or "W" and can not useed for the old activation code software.)
The sixth step:it will show “Success!”after type the right Rpatch code,then coick “OK”,means installation complete .(you can can arbitrarily changethe the key of Patch for LTE after installation complete,please attention : you do not need to do it again after type the right activation code. Just click the “OK”when prompted to type the activation code patches)
sir on 7.1 r sim 9 pro not working u means by doing this my problm will slove or steel same?
tell me yas or no?
Old 03-30-2014, 08:53   #55 (permalink)
Member: 2087480
The rpatchtool still exits after clicking on "For i5/4s iOS:7.1". any solution for this? i have an Iphone 5 running iOS 7.0.4. cheers!
Old 03-30-2014, 13:18   #56 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,058
delete the rpatch tool , try download again
The Following User Says Thank You to kinglock For This Useful Post:
Old 03-30-2014, 14:16   #57 (permalink)
Member: 73854
Try: Settings > General > Peofiles
Then remove chinasnow profile
Delete rpatch tool and re install.
Old 03-30-2014, 15:15   #58 (permalink)
Member: 2158101
The activation code please
Old 03-30-2014, 15:19   #59 (permalink)
Member: 2087480
thanks for the reply. i deleted the profile then reinstall rpatch to no avail. does it have anything to do with the isamteam source in cydia?
Old 03-30-2014, 15:20   #60 (permalink)
Member: 2087480
activation
activation code is located in the product section for $7.
Page generated in 0.40287 seconds with 8 queries
