Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 02-04-2015, 14:11   #46 (permalink)
Member: 2198519
Thanks Meter: 4
Originally Posted by GOTHAM View Post
Dear Kinglock,
Rsim 10 seems working good with my IPhone 6 Docomo Locked but I have only a big problemi: the IPhone sends continuosly SMS to Japan bringing my phone balance down!!
Do you know how to solve it?
Thanks
I fix this problem ! Rename my Docomo_jp.bundle in Docomo_jp_old.bundle then I had renamed CarrierLab in Docomo_jp.bundle.
Rsim10 works good but does not fix following problems:
-When I have 3G signal NO INCOMING Calls
-Sometimes in low signal area :ACTIVATION IS REQUIRED ,but if you have an another phone that could do tethering this is not a big problem.And also no more "your sim play a tone" sounds and problem.Sometimes when there is no signal or low after that the phone search and find signal:
DOCOMO IPHONE 6 RSIM 10(V.10.1) WORKING!
PS.NO Rsim Patch on Board!
Old 02-04-2015, 17:06   #47 (permalink)
Member: 2334039
Sonork: postbit
Got 6plus on Locked on docome I have it unlock using postpaid sim in manila (globe)
Old 02-04-2015, 22:38   #48 (permalink)
Member: 2103546
Thanks Meter: 7
Need help.. Someone please help/tell me the procedure for unlocking T-mobile usa iphone 5s ios 8.1 using rsim 9+....
Old 02-11-2015, 10:15   #49 (permalink)
Member: 2198519
Thanks Meter: 4
I Fix also this problem with GPP 3to2 patch.
When then patch is on : Edge Data and All working good then when you want 3G/4G data you need to disable patch and surf the NET!!
Rsim 10 is very stable now!!!
Thanks
Old 02-14-2015, 01:41   #50 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Originally Posted by kinglock View Post
What is the version of the iPhone 6 in this video? I followed this guide on iPhone 5s, T-Mobile, iOS 8.1 but doesn't work. You can see the signal dots but no network name....
What am I missing?
Old 02-20-2015, 06:32   #51 (permalink)
Member: 2329195
not work ): iput the r-sim 10 with tray and sim card into your iphone <> Nothing???
1. When put the r-sim 10 with tray and sim card into your iphone, you will show the page
below, in which you need to choose the carrier. If there is no carrier you want, please click “input imsi” and enter in 7 digits carrier code of your carrier(if you choose a wrong carrier ,you need to plug out the card and input again).
Old 03-04-2015, 06:56   #52 (permalink)
Member: 2249587
Thanks Meter: 11
I just tried one now, took me an hour to get it to detect as a sim again (bad contacts perhaps?), then had to fiddle around and reboot a few times and its working like a charm. Does anyone know if you can clone and edit a sim to bypass activation instead? or buy a custom sim?
Old 03-17-2015, 13:06   #53 (permalink)
Member: 1982836
Sonork: granstar
I have RSIM 10 to unlock my USA Sprint iPhone 5S, it work but can not get 4G, what patch should download to work on 3GS or 4G. I try to jailbreak IOS 7.1.1 by pangu not sucessful, result time-out. Any suggestion for help
Old 03-18-2015, 15:53   #54 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
please post more details about your sim card .
Old 03-30-2015, 20:24   #55 (permalink)
Member: 2367072
Does rsim 10 work with iPhone 5s AT&T???
Old 04-02-2015, 00:47   #56 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
i just both 10 rsim 10 and i m trying to unlock japan kddi 8.2 it just show no service what to do?
Old 04-02-2015, 08:22   #57 (permalink)
Member: 2300124
Red face Unlock Iphone 6 from T-Mobile USA with RSIM 10 ????
Hey guys,
I have an Iphone 6 from T-Mobile USA with a financed outstanding balance. Find my Iphone is off, no icloud.
I tried to unlock it with RSIM-10, but no data connection. No 2G, no 3G. The signal is fine for making calls and sms.
How can i fix it?
Thanks in advance
Old 04-02-2015, 23:22   #58 (permalink)
Member: 2320256
Sonork: 100.1661545
Thanks Meter: 50
Hello
Iphone 5s at&t lock
in 2g / 3g iphone lock
In 3g / 4g option it's ok but no signal in 2g sim card
Plz help me
Old 04-14-2015, 04:16   #59 (permalink)
Member: 975827
Does not work
I bought 5 rsim 10
Tried with ip5 tmobile ios7.0.x, ip5c sprint 8.1.2, ip6 sprint 8.1; ip6 at&t 8.1.1
None worked. Always go to actication screen and shown sim not valid. Sometimes it can go to sim application but nothing happened, shown no service
All are original sims.
Rsim10 is very bad
Old 04-23-2015, 11:36   #60 (permalink)
Member: 2375171
R sim 10 is not working with sprint iphone 5S
Page generated in 0.20826 seconds with 9 queries
