02-04-2015, 14:11 | #46 (permalink) | |
Insane Poster Join Date: Jun 2014 Location: ITALY
Member: 2198519 Status: Offline Thanks Meter: 4 | Quote:
Rsim10 works good but does not fix following problems: -When I have 3G signal NO INCOMING Calls -Sometimes in low signal area :ACTIVATION IS REQUIRED ,but if you have an another phone that could do tethering this is not a big problem.And also no more "your sim play a tone" sounds and problem.Sometimes when there is no signal or low after that the phone search and find signal: DOCOMO IPHONE 6 RSIM 10(V.10.1) WORKING! PS.NO Rsim Patch on Board! | |
02-11-2015, 10:15 | #49 (permalink) | |
When then patch is on : Edge Data and All working good then when you want 3G/4G data you need to disable patch and surf the NET!! Rsim 10 is very stable now!!! Thanks | |
02-14-2015, 01:41 | #50 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Majuro, Marshall Islands
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Quote:
What am I missing? | |
02-20-2015, 06:32 | #51 (permalink) |
Junior Member Join Date: Jan 2015 Age: 33
Member: 2329195 Status: Offline Thanks Meter: 0 | not work ): iput the r-sim 10 with tray and sim card into your iphone <> Nothing??? 1. When put the r-sim 10 with tray and sim card into your iphone, you will show the page below, in which you need to choose the carrier. If there is no carrier you want, please click “input imsi” and enter in 7 digits carrier code of your carrier(if you choose a wrong carrier ,you need to plug out the card and input again). |
03-04-2015, 06:56 | #52 (permalink) |
Insane Poster Join Date: Aug 2014 Location: Australia
Member: 2249587 Status: Offline Thanks Meter: 11 | I just tried one now, took me an hour to get it to detect as a sim again (bad contacts perhaps?), then had to fiddle around and reboot a few times and its working like a charm. Does anyone know if you can clone and edit a sim to bypass activation instead? or buy a custom sim? |
03-17-2015, 13:06 | #53 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1982836 Status: Offline Sonork: granstar Thanks Meter: 0 | I have RSIM 10 to unlock my USA Sprint iPhone 5S, it work but can not get 4G, what patch should download to work on 3GS or 4G. I try to jailbreak IOS 7.1.1 by pangu not sucessful, result time-out. Any suggestion for help |
04-02-2015, 08:22 | #57 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2300124 Status: Offline Thanks Meter: 0 | Unlock Iphone 6 from T-Mobile USA with RSIM 10 ???? Hey guys, I have an Iphone 6 from T-Mobile USA with a financed outstanding balance. Find my Iphone is off, no icloud. I tried to unlock it with RSIM-10, but no data connection. No 2G, no 3G. The signal is fine for making calls and sms. How can i fix it? Thanks in advance |
04-14-2015, 04:16 | #59 (permalink) |
Junior Member Join Date: Feb 2009
Member: 975827 Status: Offline Thanks Meter: 1 | Does not work I bought 5 rsim 10 Tried with ip5 tmobile ios7.0.x, ip5c sprint 8.1.2, ip6 sprint 8.1; ip6 at&t 8.1.1 None worked. Always go to actication screen and shown sim not valid. Sometimes it can go to sim application but nothing happened, shown no service All are original sims. Rsim10 is very bad |
