09-13-2018, 15:50 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2575895 Status: Offline Thanks Meter: 10 | IOS 12 gold master can someone please test with rsim Iphone xs, Xs max and the Xr will be compatible with rsim 12 iccid https://ios.gadgethacks.com/how-to/d...phone-0187347/ |
The Following User Says Thank You to galaxyrua For This Useful Post: |
09-18-2018, 17:41 | #5 (permalink) |
Junior Member Join Date: May 2018
Member: 2838346 Status: Offline Thanks Meter: 0 | Why the **** does everyone keep saying it would work because it works on the beta, if *** damn apple just added the requirement for all iPhone to reactivate you would feel dumb as ****, never assume that man, it's how you get yourself in trouble bud, it wouldn't require testing or anything so don't assume that it will work |
09-18-2018, 21:34 | #6 (permalink) | |
Freak Poster Join Date: Nov 2017
Member: 2783707 Status: Offline Thanks Meter: 189 | Quote:
2) It does work on freshly restored 12.0 GM. I tried it. As long as the ICCIDs aren't blocked it should work on Xr/Xs/XS Max too. | |
09-20-2018, 18:43 | #8 (permalink) | |
Really, the ICCIDs working does not depend on the iOS version, only the ICCID itself being blocked Last edited by parrotgeek1; 09-20-2018 at 18:50. | |
The Following User Says Thank You to parrotgeek1 For This Useful Post: |
09-21-2018, 21:57 | #10 (permalink) | |
Insane Poster Join Date: Dec 2017
Member: 2788786 Status: Offline Thanks Meter: 30 | IOS 12 gold master can someone please test with rsim Quote:
It works but u need to be very careful inserting the Sim and rsim together so it doesn't move around and get stuck inside the Sim tray...the reason for upside down tray is probably because of the esim inside the xs and xs max...it definitely makes rsim more annoying to use tho but if u are careful it should work I was able to get into the iccid menu on xs max. Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to djkinetic For This Useful Post: |
09-22-2018, 00:59 | #11 (permalink) | |
Junior Member Join Date: May 2017
Member: 2722741 Status: Offline Thanks Meter: 2 | Quote:
The Following User Says Thank You to jadderly For This Useful Post: |
09-22-2018, 04:07 | #13 (permalink) | |
There's no reason for it not to work considering it runs the same exact os as every other late gen iPhone. Unless apple changed there activation process. Haven't completely tested it cause I wanted to activate it on my primary carrier first. Sent from my iPhone using Tapatalk | |
09-22-2018, 04:13 | #14 (permalink) | |
Does your carrier have 2G signal? If so can you see if the "GSM Mode(2/3/4G Card)" works? My predictions a) it won't at all (most likely because Intel BB) or b) it will only work on Japanese/Chinese CDMA locked iPhones (ie not Sprint) like it did on the 7/8/X I predict that TMSI Mode will not work but can you try it (all 4 modes manual/auto); try AUTO MODE2 first | |
09-22-2018, 04:16 | #15 (permalink) | |
I'll try if no one else has once I get off work..but we can look to how other iPhones that have an exclusive Intel only baseband/modem from the last two yrs act in these modes..and safely assume they would work the same. Sent from my iPhone using Tapatalk | |
