10-16-2013, 22:36 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2047565 Status: Offline Thanks Meter: 1 | iPhone 4S, R-Sim 8+ actovation required IOS 7.0.2 I am sad! It does not work. My iphone is locked to T-mobile Germany, the SIM I want to use is vodafone GErmany. IOs is 7.0.2. The problem: After I put rsim into iphone, I choose the IMSI (e.g.2620125), then restart, after restarting I see signal but everytime "activation required". Phone is already activated with the T-mobile SIM. I tried different new SIM (vodafone, o2 and others). Everytime "activation required". Why? The cards I tried were different: nano uncut, nano cut.. Thanks for any help! |
10-17-2013, 18:33 | #4 (permalink) |
Freak Poster Join Date: Nov 2010
Member: 1449117 Status: Offline Thanks Meter: 35 | go to activation tool, install CMCC, reboot, install UNICOM, reboot, install OTHER, reboot. Then, install RSIM iROSETOOL. NOW this is important... Reboot iphone once more, when turned on, while the signal searching, go to RSIM 3 app, hit GSM mode, exit app and open iROSETOOL, then home button, then iROSETOOL again, a blank popup will appear, then hit iphone USIM (top button), then patch (top button again) it should say "patch ok" and give 2-3 minutes for signal to pop up. this worked on iOS 7.0.2 sprint and switched to tmobile and NET 10. both choices worked perfect for me. |
10-19-2013, 20:28 | #5 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2037452 Status: Offline Thanks Meter: 0 | can someone help me out I have rsim 8+ and I tried to get it to work with my telcel iPhone 5 the sim card I'm putting in to it is an 128k nano uncut tmobile sim card at first I got no service but after messing around with It I got tmobile the only problem is is that I get no bars of service and I can't text but I do get edge it's weird I have irose tool installed and unlockit installed but still nothing can anyone help? |
10-19-2013, 22:35 | #6 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1998009 Status: Offline Thanks Meter: 1 | You need to use Samsim or Rsim 7. Rsim 7 +, RSim 8, RSim 8 + does not work with t-mobile germany. I am using iphone 4s with samsim Ios 7.0.2 Telekom.DE Last edited by Artem_28; 10-19-2013 at 22:37. Reason: Error |
10-22-2013, 23:40 | #7 (permalink) | |
Member: 2039648 Status: Offline Thanks Meter: 1 | Quote:
