10-08-2013, 17:09 | #18 (permalink) |
Freak Poster Join Date: Nov 2010
Member: 1449117 Status: Offline Thanks Meter: 35 | Really nice thread. This explains the US SPRINT is the only and only killer that seems to have no solution. One thing I would try is using an UNCUT NANO and using a CUT DOWN NANO and trying both to see if there is any different among getting activation and sms issues. I have had SMS incoming and outgoing on iOS 7 but failed at 7.0.2. =/ |
10-09-2013, 03:39 | #20 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 379713 Status: Offline Thanks Meter: 55 | Quote:
We are at the user side here,right? | |
10-10-2013, 23:41 | #23 (permalink) |
Member: 1449117 Status: Offline Thanks Meter: 35 | I have found this to activate a few iPhone 5. On the activation tool program 5.0.0.0, install UNICOM, reboot, install CMCC, reboot, and then install OTHER, and this actually updates your carriers. The OTHER installation doesn't install a package, rather it updates the carrier. I have done this to a few iPhone 5 Sprint iPhones and I received a message called "iPhone is now activated" after a few seconds. You might have to reboot the iPhone 5 to search for activation. you can check if the OTHER has installed by going to settings/general/about and look at Carrer. IT should say "carrier labs 15.x" This has fixed text message issues. |
10-11-2013, 07:12 | #24 (permalink) | |
Freak Poster Join Date: Apr 2010
Member: 1288185 Status: Offline Thanks Meter: 74 | Quote:
Here we are talking about IOS 7...? Have you tried this on IOS7...? | |
10-11-2013, 07:36 | #25 (permalink) | |
10-12-2013, 01:56 | #26 (permalink) |
Freak Poster Join Date: Sep 2013 Location: Rio de Janeiro Age: 45
Member: 2032687 Status: Offline Thanks Meter: 37 | I have seven different versions: Detail for versions 5.1.2.0 and 5.1.3.0 that came out after iOS 7 but it did not work. I who did upload these files, so do not run the risk of being deleted by them. Last edited by LuizinhoMN; 10-12-2013 at 02:05. |
The Following 4 Users Say Thank You to LuizinhoMN For This Useful Post: |
10-12-2013, 02:50 | #27 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2029410 Status: Offline Thanks Meter: 0 | [/QUOTE] Hi Luizinho Ipm from Rj too and having exactly same problem as you My Sprint Iphone 5 was working fine with 6.1.4 I´ve updated to 7.0.2 and now I couldn´t send SMS neitehr use 3G... I´ve reinstalled the patch, used some tricks, but no solution until now Let´s work together to solve it meu email gui.25 do hot ponto com abraço! |
10-12-2013, 20:13 | #29 (permalink) |
Junior Member Join Date: May 2013 Location: Belgium
Member: 1933780 Status: Offline Thanks Meter: 0 | Hi, I have an iPhone 5 - sprint.. Bought many rsims hoping it would finally work. I have Base (Belgian provider) and I can sent sms but I don't have 3G... I even don't see the option to activate 3G (under settings on iPhone). But if I insert the same sim card, in an other iPhone 5, 3G works flawless Does anyone knows a solution for this issue? |
10-13-2013, 12:52 | #30 (permalink) |
Member: 379713 Status: Offline Thanks Meter: 55 | Just want to share : The bottom one is 128k card,which always giving me "No SIM" or "No service" when i use it with rsim (7/7+/8/8+) The one at the top is my daily sim. I always get a signal with that. Its 64k sim. No matter what i did to my sprint iphone 5,as this sim+rsim inserted,it always give a signal bar. But strange is, i have full functionality on both card when i was at 6.1.3/6.1.4 So,i guess its all about the patch... |
